Posted: 10/02/12 12:21 PM
During heavy Florida rain, "ABS / ACTIVE HANDLING" notice comes on. After a few driving cycles in dry weather code corrects itself and goes off. It re occurs in a week or so in wet and dry weather. Any chance it is just a dirty connection on the sensor which I believe is under the drivers side door?  Thanx in advance.
Posted: 10/02/12 06:47 PM
a few things...
YEAR....   and    can you grab any codes for the ABS/active handing system?? that will narrow it down to one of the MANY areas that it could be..
it takes more than a generic scan tool to access the ABS codes..
does your car have full digital AC... you might be able to access the trouble codes without a scan tool...
also.. if you could... when you log in.. click the MY Account link..  please put in a user name..
Posted: 10/03/12 09:11 PM
Check and clean the connections at the wheel speed sensors.  Just a thought.
