1991 Corvette wiper problem
paul09110
Posted: 12/04/11 10:21 AM
My 1991 vette has a problem with the wipers. It appears that the drivers side wiper cannot clear the hood. I have bought a brand new wiper arm but still has the problem. With the wipers in the parked position and i turn them on the drivers side wiper will get caught for a minute and when it finally clears the hood the wiper blade gets torn off. I was told to get some low profile wipers and that would cure it but have not been able to find a wiper that will work. Anyone have a remedy?
Posted: 12/04/11 05:50 PM
do you have an autozone nearby???
perhaps this would work...
Duralast Flex/Wiper Blade
For your 1991 Chevrolet Corvette 5.7L FI 8cyl
Part Number: DLF19
Eligible for FREE 2-Day Shipping
Flat style wiper blade provides superior wipe in any weather. Unique adapter system provides replacement for conventional blades as well as factory installed flat blades
Blade provides equal pressure on windshield for a smooth wipe
Frameless construction prevents ice and snow build up
Offers upgrade from conventional wiper blades
Comprehensive instructions make installation simple
Part Number: DLF19
Weight: 0.4 lbs
Notes: Front - driver side and passenger side.Wiper Blades: one per pack.
Attached Spoiler / Aerofoil: Yes
Heated: No
Quick Connect Hardware Included: Yes
Assembly Color: Black
Backbone Material: Plastic
Backbone Structure: Beam
Design: All-Season
Material: Rubber
Size (In): 19 in
Wiping Edges: 1
paul09110
Posted: 12/05/11 04:27 AM
Thank you I will try those blades. Hope they work
Posted: 12/05/11 11:40 AM
i should have posted this... edit.. i think i looked this up for a 94.. not a 91..
9108291Y10 019
001 19192671 BLADE. Rear Window Wiper. Windshield Wiper. Windshield Wiper Blade.
BLADE,WSW(20 IN 500 MM, METAL)(DRIVER AND PASSENGER SIDE)(ACDelco #8-4420)(ALL SEASON METAL). Required: 02For: YY07 (1984-1996) (1992 - 1994). For: YY... Show More $6.20
001 89000978 BLADE. Rear Window Wiper. Windshield Wiper. Windshield Wiper Blade.
BLADE,WSW(20 IN 510 MM)(DRIVER AND PASSENGER SIDE)(ACDelco #8-120)(ALL SEASON PLUS). Required: 02For: YY07 (1984-1996) (1992 - 1994). For: YY07 (1984-... Show More $19.90
001 89001048 BLADE. Rear Window Wiper. Windshield Wiper. Windshield Wiper Blade.
BLADE,WSW(20 IN 510 MM)(DRIVER AND PASSENGER SIDE)(ACDelco #8-420)(ALL SEASON). Required: 02For: YY07 (1984-1996) (1992 - 1994). For: YY07 (1984-1996)... Show More $9.14
001 15184702 BLADE. Rear Window Wiper. Windshield Wiper. Windshield Wiper Blade.
BLADE,WSW(18")(TRICO)(PIN TYPE)(16.062). Required: 02For: Y W/S ARM & BLADE(C18)(EXPORT) (1994-1994) (1994 - 1994). For: Y W/S ARM & BLADE(C18)(EXPORT... Show More $11.67
001 12363800 BLADE. Windshield Wiper Blade.
BLADE,WSW(20",USE W/INSERT 14069842)(BLACK)(ANCO). Required: 02For: Y (EXC W/S ARM & BLADE(C18) (1988-1994) (1992 - 1994). $11.67
001 89001009 BLADE. Windshield Wiper Blade.
BLADE,WSW(20 IN 510 MM)(DRIVER AND PASSENGER SIDE)(ACDelco #8-2202)(PERFORMANCE). Required: 02For: YY07 (1984-1994) (1992 - 1994). For: YY67 (1986-199... Show More $13.10
001 19114808 BLADE. Windshield Wiper. Windshield Wiper Blade.
BLADE,WSW(19 IN 480 MM)(DRIVER AND PASSENGER SIDE)(ACDelco #8-919)(BEAM WIPER BLADE). Required: 02For: YY07 (1984-1994) (1992 - 1994). For: YY67 (1986... Show More $21.82
001 19162951 BLADE. Windshield Wiper. Windshield Wiper Blade.
BLADE,WSW(19 IN 480 MM)(DRIVER AND PASSENGER SIDE)(ACDelco #8-9919)(BEAM W/SPOILER). Required: 02For: YY07 (1984-1994) (1992 - 1994). For: YY67 (1986-... Show More $25.00
001 19252694 BLADE. Windshield Wiper. Windshield Wiper Blade.
BLADE,WSW(19 IN 480 MM)(DRIVER AND PASSENGER SIDE)(A ADVANTAGE BEAM). Required: 02For: YY07 (1984-1994) (1992 - 1994). For: YY67 (1986-1994) (1992 - 1... Show More $15.97
001 89001090 WIPER. Rear Window Wiper. Windshield Wiper. Windshield Wiper Blade.
WIPER,W/S(20 IN 510 MM)(01.067)(DRIVER AND PASSENGER SIDE)(ACDelco #8-5204)(ALL SEASON). Required: 02For: YY07 (REFILL) (1984-1996) (1992 - 1994). For... Show More $6.02
001 89001091 WIPER. Rear Window Wiper. Windshield Wiper. Windshield Wiper Blade.
WIPER,W/S(20 IN 510 MM)(01.067)(DRIVER AND PASSENGER SIDE)(ACDelco #8-5205)(UNIVERSAL PLASTIC). Required: 02For: YY07 (REFILL) (1984-1996) (1992 - 199... Show More $8.92
001 89001242 WIPER. Rear Window Wiper. Windshield Wiper. Windshield Wiper Blade.
WIPER,W/S(20 IN 500 MM)(01.067)(DRIVER AND PASSENGER SIDE)(ACDelco #8-5200)(ALL SEASON PLUS). Required: 02For: YY07 (REFILL) (1984-1996) (1992 - 1994)... Show More $6.90
001 89001089 WIPER. Windshield Wiper Blade.
WIPER,W/S(20 IN 510 MM, TUBULAR)(01.067)(DRIVER AND PASSENGER SIDE)(ACDelco #8-5203)(PERFORMANCE). Required: 02For: YY07 (REFILL) (1984-1996) (1992 - ... Show More $9.18
001 12399988 WIPER. Windshield Wiper Blade. INSERT. Rear Window Wiper. Windshield Wiper.
WIPER,W/S(ANCO-18")(BLACK). Required: ARFor: Y W/S ARM & BLADE(C18) (1988-1994) (1992 - 1994). $7.50
003 14057582 CONNECTOR. Windshield Washer
CONNECTOR,WSWA NOZ HOSE(ELBOW). Required: 01For: Y (1984-1996) (1992 - 1996). $4.66
003 14057583 CONNECTOR. Windshield Washer
CONNECTOR,WSWA NOZ HOSE(TEE). Required: 01For: Y (1984-1996) (1992 - 1996). $21.08
003 22094772 CONNECTOR. Windshield Washer
CONNECTOR,WSWA NOZ HOSE(10.154). Required: 01For: Y (1992-1996) (1992 - 1996). $20.44
004 22144264 ARM. Windshield Wiper Arm
ARM,WSW(INCLS NOZZLE) - RH. Required: 01RHD. For: Y (1984-1994) (1992 - 1994). $108.27
004 22144265 ARM. Windshield Wiper Arm
ARM,WSW(INCLD NOZZLE) - LH. Required: 01LHD. For: Y (1984-1994) (1992 - 1994). $106.18
005 10268251 RETAINER. Windshield Washer.
RETAINER,WSWA NOZ HOSE CONN(10.155). Required: 02For: Y (1994-1996) (1994 - 1996). $25.00
007 22039698 BRACKET. Windshield Wiper Transmission
BRACKET,WSW ARM SHF. Required: 02For: Y (1984-1996) (1992 - 1996). $12.60
009 10272127 RAMP. Windshield Wiper Arm
RAMP,WSW ARM PARK. Required: 02For: Y (1984-1994) (1992 - 1994). For: Y (1995-1996) (1995 - 1996). $33.08
010 14057582 CONNECTOR. Windshield Washer
010 14057583 CONNECTOR. Windshield Washer
010 22094772 CONNECTOR. Windshield Washer
011 14100225 BOLT. Windshield Washer. Windshield Wiper Motor. Windshield Wiper Transmission.
BOLT,WSW TRANS REINF(M6.60X1.69X18). Required: 06For: Y (1984-1996) (1992 - 1996). $4.25
012 14047426 REINFORCEMENT. Windshield Wiper Transmission
REINFORCEMENT,WSW TRANS(10.160). Required: 02For: Y (1984-1996) (1992 - 1996). $7.37
014 12073639 HARNESS. Body Wiring
HARNESS,WSW & WSWA WRG. Required: 01For: Y (1988-1996) (1992 - 1996). $45.43
015 19179659 MOTOR. Windshield Wiper Motor
MOTOR,WSW(EXC CRANK ARM AND COVER)(INCLS HARNESS)(ORDER T/W PN 12117339 WIRING HARNESS)(ACDelco #19179659). Required: 01For: Y (1984-1996) (1992 - 199... Show More $173.02
016 20489125 GASKET. Windshield Wiper Motor. SEAL.
GASKET,WSW MOT. Required: 01For: Y (1984-1996) (1992 - 1996). $6.79
017 10258428 STOP. Windshield Wiper Arm. Windshield Wiper Blade.
STOP,WSW BLADE. Required: 01For: Y (1992-1996) (1992 - 1996). $27.32
024 22111432 PUMP. Rear Window Wiper. Windshield Washer. Windshield Washer Pump.
PUMP,WSWA(ACDelco #22111432). Required: 01For: Y (1992-1996) (1992 - 1996). $60.04
024 89001128 PUMP. Rear Window Wiper. Windshield Washer. Windshield Washer Pump.
PUMP,WSWA(10.146)(ACDelco #8-6716)(ALL MAKES). Required: 01For: YY07 5.7J(LT5) (1992-1995) (1992 - 1995). For: YY07-67 5.7-5(LT4) (1996-1996) (1996 - ... Show More $33.16
028 14062552 BRACKET. A/C Wiring. Chassis/Engine Wiring Harness. Computer Control Sensors. Electronic Brake Control. Inflatable Restraint System.
BRACKET,WHL SPD SEN WRG HARN CLIP(02.559). Required: 01BRACKET,WHL SPD SEN WRG HARN CLIP(02.559). Required: 02For: Y (1987-1995) (1992 - 1995). For: Y... Show More $24.68
029 22094774 ELBOW. Windshield Washer
ELBOW,WSWA NOZ HOSE(10.154). Required: 01For: Y (1992-1996) (1992 - 1996). $1.90
