1984 headlights
BSenzina
Posted: 09/17/10 06:08 PM
I just bought my 1st Corvette.....A nice 1984....It has a problem with the headlights.....the left comes open easily when turned on. The right stays closed. If i bump it a couple of times, it opens. Can anyone lead me in the right direction as to a possible cause and remedy???? Are they vacuum or electric motors? Thanks in advance.
Posted: 09/18/10 05:36 AM
corvette lazy eyes....
strange that it works sometimes...   but you might find help in this article
these cover the headlight lift motors
http://www.corvettefever.com/howto/33098/index.html
http://www.vetteweb.com/tech/vemp_0906_chevy_corvette_c4_headlamp_motors/index.html
http://www.vetteweb.com/buyersguide/vemp_0407_c4_corvette_headlight_motor_replacement/index.html
this one covers replacing the headlight bulbs without loosing fingers...
http://www.corvettefever.com/howto/39020/index.html
read up.....    do some testing..    once you read the articles linked. you may be able to handle it..   its a popular problem....
smat
Posted: 12/05/10 06:58 AM
I just had the same problem in my case it was a strip gear 20$ fix takes about 1hr to do take out the head light motor open it up and there will be two gears i relaced both but only one needed it but i had it apart so i did both now it works like new
