C5 & NITROUS
genewalp0
Posted: 09/01/10 06:19 AM
ANYONE OUT THERE KNOW WHAT COLOR WIRE AT THE (TPS) THROTTLE POSITION SENSOR THAT YOU TAP INTO TO PICK UP THE SPEED/TACK REFERENCE INORDER TO HOOK UP THE RPM ON/OFF COMPUTER WHEN INSTALLING NOS ON AN 01 C5
Posted: 09/01/10 06:33 AM
woh..!!!...  the TPS has a 0.50 volts to 4.5 volts signal to the ecm to tell throttle position.. there is also a ground wire... and a 5.0 voltage reference wire...  there is NO tach signal on any of those wires...
and since you have a drive by wire system...  it has more wires than that...
i don't know where on a 6.0 motor to hook up the NOS computer ...
call the manufacturer...   read the instructions that came with it..
if you need a wiring diagram for the electronics....
autozone.com .. log in at the upper right corner.. select your car...  click on the repair info...
there is a link for wiring diagrams....   they are printable...
ahh... nitrous...  one friends 67 camaro.. ran 12.28@118 without... 10.60 @132 with..  in 1983... with a full exhaust ..  and a 327/ 331 Sj sbc...
