Chevy 468 BB build
Newbee468
Posted: 02/11/18 01:17 PM
Hey guys, I'm new to the Chevy world, been looking for a long time, just recently was in a position to purchase a 68' camaro SS. A lot of work has been done to the car already I'm just curious if it is making as much as it should be. Below are the specs on the engine that were given to me. Let me know your thoughts. Thanks.
A 468 ci full-roller motor (aluminum heads)
Brand new lines throughout (Starlite/Nomex hoses and fuel lines);
Vehicle is also outfitted with a Weind intake. Timing is set at 12 degrees;
Drive shaft is a C6 31 Spline Slip Yoke for a 1330 U-Joint;
The motor has a compression ratio of 10.7:1 (Wiseco World Products heads), tune[/iframe] is set at 74 PRI, 79 sec, 36 deg timing, cam shaft of 720 degrees lift and 330 degrees duration, hydraulic roller rockers, and a 800 CFM Holley carburetor;
The heads are square port and outfitted with ARP studs and bolts. Headers are brand new and ceramic coated (3 inch);
