350 build need options!!
justinny914
Posted: 10/05/15 06:01 PM
hi my name is justin and im doing my first chevy engine build. i have a 350 chevy block bored .60 over and has a factory forged crank. was wondering if you guys can tell me how to build my motor to 400hp and maybe more or atleast point me in a direction on how to build it. money isnt a problem since i dont plan on finishing this motor till summer of 2016 so ill be buying parts thru out the winter. help will be appericated thanks
Just Try It1
Posted: 10/05/15 09:27 PM
horsepower is in the cam and head selection..
did they sonic test the block walls before they bored it..
there are a few dozen articles on this search window use..
i searched for 350 build..
use the search window above right.. type in 350 build
ARP main and head bolts or studs.. your choice at this level.. you are already expected to have them in the rods..
RODs.. you will probably get by with stock rods.. but H beam rods are probably better..
personally  i will only run Clevite "77" bearings in a performance motor..
i almost always port and polish the rear main cap oil passage.. as this is dirt easy to do and you can do it away from the engine block..
3Fasy1z
Zfmfh7v
Ozh3tqx
Wc79vim
Xbtawr5
9B0pb9i
Xiaquih
8X1yreg
Gnsdwhc
Mqeqewd
this still needs a lot of polishing.. its just roughed in..
justinny914
Posted: 10/06/15 03:49 AM
Block was sonic tested and decked
