Gmc temp gauge
Lsterling
Posted: 04/22/14 02:00 PM
My 09 GMC V6 pick-up seems to have an issue with the engine temp sending unit.  The original lasted until 9 months ago.  I replaced it with a dealer part which lasted  until 3 days ago.  I replaced it with the dealer part again and it lasted 2 days.  What am I missing?
Posted: 04/22/14 06:38 PM
can you narrow down the actual truck model.. rating and engine size.
there are several different engine coolant temp sensors used in 2009 GMC models.
usually the sending units get 5 volts from the computer and share a ground connection..   the temp variable resistor changes the amount of voltage sent to the ground circuit..  the computer looks at the left over voltage and takes that as a specific signal..
now.. because some of the ground side of these circuits are also grounded to the engine block..
if you have a bad ground connection on the several of them around the engine bay.. you could have enough stray voltage to burn things out..
do you own a digital volt meter..  if you don't you can get them from 5 to 20 bucks .. digital has numbers that change.. no needle swinging across..
print this..
Voltagedroptesting
perform at least the 4 part version of that test and post results.
i have found so many ground issues on all kinds of cars and trucks.. i came up with this quick test..
post results by number
1.____
2._____
3.______
4._______
Lsterling
Posted: 04/23/14 12:48 PM
Thanks for the input.  I will definitely look into the ground issue.  That makes even more sense when I consider the on and off functioning of my new sending unit.
Lsterling
Posted: 04/23/14 12:51 PM
Thanks for the input.  I will definitely look into the ground issue.  It makes sense considering the on and off functioning of the sending unit
