Please help!!
Abner Lopez Lamboy
Posted: 06/30/14 05:27 PM
I need to know identify my GM engine. I found a many number on block but in many web page the number vin 192089392  K0502F2  was not found. If anyone have a recomendaci√≥n please write it.
Posted: 07/01/14 12:23 AM
K0502
K is GM of canada
05 is MAY
02 is the second day of the month..
and could the last digits actually be
FZ  instead of ***
6-250
Chev Pass. 66-67
how about some casting numbers off the block..  and or casting numbers off the head..  there is also a julian date.. looks like this (\)b147(\)  the pattern on both sides are usually screw heads cast into the part..  B is feburary.. 14th and 7 would be the year.. 67, 77, 87, 97..
Abner Lopez Lamboy
Posted: 07/01/14 08:37 PM
the casting number is  3956618 and the date is 1368 I will be grateful if you can help me
Posted: 07/02/14 09:53 PM
4" bore medium  journal 327 or 350 block..  68 thru 79
large journal are actually 400 blocks as they have bigger main journals.. early small blocks have small journals.. 350s are actually a medium journal.
how about pictures of the stamping number off the front of the block.. and the julian date..
could it be the 136th day of 1968????? or the 136th day of 1978..
depends on what the actual stamping number suffix turns out to be..
so it could be a late 70s 350 chevy...   probably with 441 or 624 heads
