carburetor tuning problem
joshcanfield
Posted: 04/25/13 08:12 AM
I had my engine put in by a mechanic my friend suggested....bad idea i know... well I have found problem after problem from what this mechanic did...everything is half-assed and done cheapely and very poorly.
I am having problems working on my carb. I cant seem to find the tuning screws.
here is what I see...
Imag0377si
Imag0379e
so is this normal mixture keys? if so how do I get down in there to adjust them?
Posted: 04/25/13 08:26 AM
Josh, your pictures are so large when compared to the veiwing window, it is hard to tell exactly what we're looking at.
The screw under or next to the throttle linkage is the idle SPEED screw.
The air bleed screws are at the front, in the throttle blade plate/section of the carb.
The way to set the air bleeds is to use a vacuum gauge attached to manifold vacuum port. Turn the air bleed screws, one at a time, in or out until the highest vacuum reading is obtained. THEN set the idle speed with the idle speed screw. You may have to go through the process two or three times to get air bleed and idle rpm optimized.
joshcanfield
Posted: 04/25/13 08:53 AM
ya sry about the image size the last time i posted in the forum people were saving them to their computer so they can resize it themselves. the problem I am having is getting to the screws to turn them. I can fit a needle nose in there is there a better way to adjust them in or out...also is this carb even worth fighting with or should I look into getting a different one
Posted: 04/25/13 09:53 AM
Carbs are a personal preference...what one likes or learns to mess with.
Posted: 04/25/13 02:12 PM
the second picture shows the idle mixture screws.....  those take a special DOUBLE D tool... easily found at parts stores...
the first picture shows a hex head with a slot screw kinda on the side of the carb.. thats the idle speed screw...
you will usually need a pair of tools...
OEM/Carburetor adjusting tool  Part Number: 25062
11-1/2 In. flexible shaft easily reaches into confined areas
Includes 5 quick change adapter tips for multiple applications
Convenient adapter tip storage located in handle and plastic boot
Sizes: double D, 1/4 In. hex, 3/32 In. hex, 2.5 mm hex, 4.5 mm hex
Part Number: 25062
Bits/Sockets Included: Double D, 1/4" hex, 3/32" hex, 2.5mm hex, 4.5mm hex
or
GP Sorensen/Adjustment tool Part Number: 779-5517
for carb adjustments ... you will also need a vacuum gauge... these read from 30 inches of vacuum to 15 pounds of pressure..
getting the carb idle mixture adjustment correct is like balancing on a ball..
you will need more info ..
i will put up some later ... but you might want to google this term
idle mixture adjustment quadrajet
you will find several sites and pdf files on it..
Ravoll
Posted: 04/26/13 06:57 AM
I use a piece of 8 mm hollow aluminum tubing.It's been slightly pinched closed at one end so I can turn the "D" heads of the mixture screws.It's pretty redneck but it works,and was a lot cheaper than buying special tools that will only be used once.I also use the same thing to adjust my metering rod plunger.
