1999 5.7 vortec
crazy29
Posted: 08/30/13 05:18 PM
changed the lower intake gaskets now i cant get it to fire. no spark at coil or plugs. any help would be appreciated
Posted: 08/30/13 09:51 PM
three wire connector to the cam sensor in the distributor housing..
connector to the crank sensor on the bottom of the timing cover.
did you align the crank to TDC #1 compression... and set the distributor so the rotor is pointing at the \8/ in the housing...
did the ignition module and the ignition coil both get plugged back in???
