Engine overheat
Lsterling
Posted: 04/28/13 12:40 PM
My 09 GMC Sierra  6cyl  is telling me I have an engine overheat problem while my temp gauge is reading way below normal.  Fluids are good, I'm not seeing anything hot under the hood and the truck is running normally.  I'm confused.
Posted: 04/28/13 01:31 PM
which device is telling you over heat???
the temp gauge is below normal???   that might indicate the LOSS of the engine coolant..
or a warning light on the dash..???
do you have the factory owners manual...
page 5-33
Checking Coolant
The coolant surge tank is located in the engine
compartment on the passenger side of the vehicle.
See Engine Compartment Overview on page 5-16
for more information on location.
The vehicle must be on a level surface when checking
the coolant level.
Check to see if coolant is visible in the coolant surge
tank. If the coolant inside the coolant surge tank is
boiling, do not do anything else until it cools down.
If coolant is visible but the coolant level is not at or
above the FULL COLD mark, add a 50/50 mixture of
clean, drinkable water and DEX-COOL® coolant at the
coolant surge tank, but be sure the cooling system is
cool before this is done. The coolant level should be at or above the
FULL COLD mark. If it is not, you may have a
leak in the cooling system.
If the vehicle has a low coolant sensor and the
LOW COOLANT LEVEL message comes on and
stays on, it means you are low on engine coolant.
See “LOW COOLANT LEVEL” under DIC Warnings
and Messages on page 3-66.
If no coolant is visible in the surge tank, add coolant as
follows:
1. Remove the coolant
surge tank pressure
cap when the cooling
system, including the
coolant surge tank
pressure cap and upper
radiator hose, is no
longer hot.
Turn the pressure cap slowly counterclockwise
about one full turn. If you hear a hiss, wait for that to
stop. A hiss means there is still some pressure left.
2. Keep turning the pressure cap slowly, and remove it.
3. Fill the coolant surge tank with the proper mixture
to the FULL COLD mark.
4. With the coolant surge tank pressure cap off,
start the engine and let it run until the engine
coolant temperature gage indicates approximately
195°F (90°C).
By this time, the coolant level inside the coolant
surge tank may be lower. If the level is lower, add
more of the proper mixture to the coolant surge
tank until the level reaches the FULL COLD mark.
5. Replace the pressure cap. Be sure the pressure
cap is hand-tight and fully seated.
6. Verify coolant level after engine is shut off and the
coolant is cold. If necessary, repeat coolant ?ll
procedure Steps 1 through 6.
Notice: If the pressure cap is not tightly installed,
coolant loss and possible engine damage may occur.
Be sure the cap is properly and tightly secured.
Engine Overheating
If the vehicle has the DURAMAX® Diesel engine, see
the DURAMAX® Diesel manual for more information.
The vehicle has several indicators to warn of engine
overheating.
You will ?nd a coolant temperature gage on the vehicle’s
instrument panel. See Engine Coolant Temperature
In addition, you will ?nd ENGINE OVERHEATED STOP
ENGINE, ENGINE OVERHEATED IDLE ENGINE,
and ENGINE POWER IS REDUCED messages in the
Driver Information Center (DIC) on the instrument panel.
See DIC Warnings and Messages on page 3-66.
You may decide not to lift the hood when this warning
appears, but instead get service help right away.
See Roadside Assistance Program on page 7-7.
If you do decide to lift the hood, make sure the vehicle
is parked on a level surface.
Then check to see if the engine cooling fans are
running. If the engine is overheating, both fans should
be running. If they are not, do not continue to run
the engine and have the vehicle serviced.
Notice: Engine damage from running your engine
without coolant is not covered by your warranty.
See Overheated Engine Protection Operating Mode
on page 5-38 for information on driving to a safe
place in an emergency.
Notice: If the engine catches ?re while driving
with no coolant, the vehicle can be badly damaged.
The costly repairs would not be covered by the
vehicle warranty. See Overheated Engine Protection
Operating Mode on page 5-38 for information on
driving to a safe place in an emergency.
If Steam Is Coming From The Engine
Compartment
{ CAUTION:
Steam from an overheated engine can burn you
badly, even if you just open the hood. Stay away
from the engine if you see or hear steam coming
from it. Turn it off and get everyone away from the
vehicle until it cools down. Wait until there is no sign
of steam or coolant before you open the hood.
If you keep driving when the vehicles engine is
overheated, the liquids in it can catch ?re. You or
others could be badly burned. Stop the engine if
it overheats, and get out of the vehicle until the
engine is cool.
If No Steam Is Coming From The
Engine Compartment
The ENGINE OVERHEATED STOP ENGINE or the
ENGINE OVERHEATED IDLE ENGINE message,
along with a low coolant condition, can indicate a
serious problem.
If you get an engine overheat warning, but see or
hear no steam, the problem may not be too serious.
Sometimes the engine can get a little too hot when you:
• Climb a long hill on a hot day.
• Stop after high-speed driving.
• Idle for long periods in traffic.
• Tow a trailer. See Towing a Trailer on page 4-53.
If you get the ENGINE OVERHEATED STOP ENGINE
or the ENGINE OVERHEATED IDLE ENGINE message
with no sign of steam, try this for a minute or so:
1. Turn the air conditioning off.
2. Turn the heater on to the highest temperature and
to the highest fan speed. Open the windows as
necessary.
3. If you are stopped in a traffic jam, apply the brake,
shift to N (Neutral); otherwise, shift to the highest
gear while driving — D (Drive) or 3 (Third).
If the temperature overheat gage is no longer in the
overheat zone or an overheat warning no longer
displays, the vehicle can be driven. Continue to drive
the vehicle slow for about 10 minutes. Keep a safe
vehicle distance from the car in front of you. If the
warning does not come back on, continue to drive
normally.
If the warning continues, pull over, stop, and park the
vehicle right away.
If there is no sign of steam, idle the engine for
?ve minutes while parked. If the warning is still
displayed, turn off the engine until it cools down.
Also, see “Overheated Engine Protection Operating
Mode” later in this section.
Operating Mode
If an overheated engine condition exists and the
REDUCED ENGINE POWER message is displayed,
an overheat protection mode which alternates ?ring
groups of cylinders helps prevent engine damage.
In this mode, you will notice a loss in power and
engine performance. This operating mode allows the
vehicle to be driven to a safe place in an emergency.
Driving extended miles (km) and/or towing a trailer in
the overheat protection mode should be avoided.
Notice: After driving in the overheated engine
protection operating mode, to avoid engine damage,
allow the engine to cool before attempting any
repair. The engine oil will be severely degraded.
Repair the cause of coolant loss, change the oil
and reset the oil life system. See Engine Oil
onpage5-17.
Lsterling
Posted: 04/28/13 03:30 PM
My coolant level is good, the truck runs good, engine, radiator etc. seems reasonable.  After 50 mile drive home there is no seem or boiling,  I'm thinking I may have a sending unit issue.
Christopherthao
Posted: 05/10/13 03:30 AM
There may be your temprature sensor damaged or malfunctioned, such showing you overheating indication check with your mechanic to test it.
Posted: 05/13/13 11:15 PM
Very simply put! If the coolant is not being blown out, then the coolant and engine are not over-heating. Follow Wayne's diagnosis and it will help you clear your problem up. Also make sure you have a good clean ground at the sensor...
Christopherthao
Posted: 05/22/13 11:53 PM
As Wayne has suggested most of the common reasons and their solution here already, if you need some additional information to resolve your problems check out some expert blogs and article pages available online with automotivezone, hiperformer and Wikipedia pages. This will assist you to resolve all type of engine problems including the overheating issue.
