Drop spindles for front wheel drive chevys
harpdiggity
Posted: 03/22/12 10:05 PM
Confused Does anybody make a drop spindle for a 2004 monte carlo?
Ravoll
Posted: 03/23/12 06:26 AM
No,but there are lowering kits containing shorter struts or just lowering springs.Without getting into suspension geometry ,FF vehicles don't use "spindles"
per say on the front axles.In the rear,yes,but rear axles on most FF cars are or the "trailing" type and nothing like conventional spindles like you may be thinking.
harpdiggity
Posted: 03/24/12 08:46 AM
How low can you go without compromising the geometry? Is air an option? I want to decrease the fender wheel gap without feeling like I am shattering my teeth while rolling over sand..... Laugh
Ravoll
Posted: 03/25/12 05:52 AM
You can go with the spring or strut options,to lower your vehicle.You can drop it this way without worrying about geometries.They'll be figured in for you.Realignment will be needed at whatever height you decide on.
Air ride requires for the most part cutting and welding. Springs and struts are bolt on parts.
