From stock cam to performance cam on 4.8 L V8
Red2007
Posted: 04/14/12 05:14 PM
I want to change my stock cam to a performance one. I drive a 2007 classic Chevy with a 4.8L, what would u recommend goin with for a daily driver. I'm looking for power on the take off as well as over all performance. I don't know anything about this but I would like to learn alil.Also, the best prices on where to get what I need.
Posted: 04/15/12 09:53 AM
red2007
Your going to have to contact a cam manufacturer to see if someone can make a cam for you..I can tell you this it will be expensive..I didn't answer the post because there are no manufactured cams for that engine...Why because its not a popular engine...You could contact your chevy dealer and see if they make a hotter cam for that engine....
My advice to you is find a 5.3 and 4L30E or 4L60E trans at a boneyard get as many parts and equiptment from it as you can..that means all the electronics..PCM  ECM. I know you said you want to learn so go to this site and see if there is a technical book you can read before starting a huge project like this...Its well worth the swap and you will have power as you want..www.cartechbooks.com   I know this is not what you expected but there is NO easy way out as the 4.8 is a slug..it was built for mpg and around town and highway use.Never a performance engine....Good Luck...
Red2007
Posted: 04/15/12 09:59 AM
Thanks for yr advice.
Posted: 04/15/12 04:09 PM
Your very welcome:
Red2007
Posted: 04/16/12 06:51 PM
What bolt ons would u recommend , I have a K&N cold air intake, throttle body spacer, an corvett cervo, with dunk flomaster exhaust
Posted: 04/17/12 05:42 AM
red2007
That will depend on what will fit and what you decide to ....Cold air boxes are worth good HP  spacers work but be carefull if you have drive by wire don't go in that box or even drop it..(it's loaded with plastic gears) believe me you can screw that up in a heart beat... What Covette servo do you mean...Don't go too big on your exhaust it will take power away....
The difference between a cold air box and not..My brothers 2002 ZO6. we ran it at Daytona in a club that he belongs to.Without a cold air box and the car was setup to the video GM provides we went 174mph and that was a corrected speed on 3 laps around Daytona..I'm sure driving it with a cold air box that car would have gone 180mph....
Jimmy Barber
Posted: 09/30/15 05:16 PM
I put a LS3 cam in my 4.8 in a 1972 Nova.  I know this is not a great test but I have an app on my phone that will time 0-60.  With stock cam my best was 5.9 sec.  With the LS3 cam it is 5.6.  There is almost no lope.  It feels about the same as the stock cam to 3000 rpm and then it pulls much harder to 6000 rpm.  I paid $89 from Pace Performance.
