What kind of Transmission For 1996 Chevy Silverado Truck
Gina1
Posted: 04/01/11 09:01 AM
HELP Could someone please tell me what kind of transmission is in a 1996 Chevy Silverado Truck it has a 5.7 litre vortec motor. I had this transmission rebuilt a little over a yr ago and reverse went out first still can drive but my overdrive is going out. Is there something I could check that could be the problem or is it  needing rebuilt again? I have found a wreck 96 truck but i need to make sure its the right transmission cause I was told I have the rare one when I had it rebuilt just cant rememeber if its 700R4 or 4L60E. Any advice would be appreciated Thanks Gina
Gina1
Posted: 04/01/11 04:12 PM
I found out that it is a 4L60E aka a M30 posted this incase it could help someone else out
Posted: 04/01/11 04:49 PM
Yes on the 4L60E.
No on the trans rebuild shop...wrong place to go, trans should live much, much longer than a year or so.
Posted: 04/02/11 08:39 PM
A 4L60 or a 4L80 would probably work. Just check all the necessary dimensions. The 4L80 might be an electroni switch. Thats one strong trans it weighs a ton. Did you have a 700R4 in your 1999? Good luck.
