94 CAMARO WONT RUN AFTER WARM
po_choppa
Posted: 02/15/10 04:35 PM
MY 94 CAMARO Z28 WILL START AND RUN FOR ABOUT 10 MINS AND THEN IT STARTS TO MISFIRE AND DIE OUT. AFTER THAT I CANT GET IT TO START BACK UP FOR A DAY. I THOUGHT CONTROL MODULE AT FIRST, BUT I WAS WRONG. ANY OTHER IDEAS?
gettnlarge01
Posted: 02/15/10 05:24 PM
is it a stock camaro?
Posted: 02/16/10 06:47 AM
change  the ignition coil....    take it off and look at it... see if it have white dust marks on the core close to the frame of the coil.. that indicates high voltage leaks...
ignition coils are the easiest thing to change..
while you have it off.. you can take the module in to some auto parts stores for testing..     have them test it six times in a row.. that will heat the  module.. if its going to fail when it heats up.. six times it will show up..
be sure that there is silicone dielectric grease under the module...   no grease to transfer the heat out of the module.. the engine will die usually in 10 or 15 minutes when the module overheats and the circuit board inside separates ...
there are also several other things that it could be ... like a crank sensor..
edit...
it could also be the fuel pump failing..    dirty fuel filter.  if you find a clogged fuel filter... you may also have a damaged fuel pump....  is the fuel pump noisy????
after it dies.. when you turn on the key.. can you hear the fuel pump spin up for 2 seconds..
one trick to start a stuck fuel pump...   while the someone is cranking the motor.. pound on the bottom of the fuel tank.. this will almost always get the fuel pump to start once more time..
bdvdw
Posted: 02/16/10 12:59 PM
is your exuast plugged?
just an oddball thing to check.
but i've seen it happen.
did you pull the plugs after it dies out to see if any are wet.
another lt1 missfire issue is since the distributer is under the water pump, sometimes the water pump leaks into the distributor cap. known to be a common problem with those engine's.
can you keep it running if you throttle it?
Administrator
Posted: 02/17/10 06:41 AM
It's a '94 Z28, that's means opti-spark (opti-fail) so I don't think there's an external coil.
If it's a V-6, different story.
I'd start with the fuel pump relay. Sounds like it gets hot just after starting and fails. An easy way to determine this, start the car, let it run and die like you described, turn the key off, pop the gas cap, have someone turn the car, and listen closely to hear if the fuel pump comes on. If you hear the pump, that eliminates the relay and the pump.
When was the last time you changed the fuel filter?
bdvdw
Posted: 02/17/10 01:56 PM
wow. it's been so long since my first and only fuel filter got plugged. i plumb fergot. about that one. good call.
po_choppa
Posted: 02/18/10 06:31 PM
THE PUMP STILL COMES ON. I GET GOOD PRESSURE. I HAVE BEEN HEARING THAT THE OPTI SPARK WILL GIVE ME THIS PROBLEM. IM LOOKING INTO THAT. I HOPE I FIGURE IT OUT SOON.
gettnlarge01
Posted: 02/19/10 04:42 PM
sounds like the ignition
Posted: 02/19/10 09:28 PM
ignition coil picture   20 bucks at AZ
http://contentinfo.autozone.com/znetcs/product-info/en/US/wl2/C846/image/8/
ignition module picture    about 85 bucks... and AZ and others can test them in the store... do it six times in a row..
http://contentinfo.autozone.com/znetcs/product-info/en/US/wl2/DR174/image/8/
here is your optispark cap and rotor...   close to 200 for an after market unit..
http://contentinfo.autozone.com/znetcs/product-info/en/US/wl2/DR2032/image/8/
here is the distributer...  optispark..  rebuilt...   about 250.. with the core charge...
http://contentinfo.autozone.com/znetcs/additional-prod-images/en/US/c11/30-1832/2/image/8/
why not change the cheepest part first...  the coil... it has worked for me a BUNCH of times...  while you have it off.. take the module to the parts store.. have them test it six times in a row.. takes about 2 minutes..
this product gets spread under the ignition module..
http://contentinfo.autozone.com/znetcs/product-info/en/US/ptx/81150/image/8/
allows the transfer of heat from the module to the heat sink.. or else the module will over heat in about 10 to 30 minutes and FAIL... until it cools back off...   sometimes they fail completely..  but once thermally damaged.. they are junk...  even if they work right now.. the six time test will usually catch the thermal damage..
to make the links clickable..  copy the text.. paste it into an email to your self....  as many answers as i post all day and Night long.. i wish i could figure out how to do it.. ... but it does not matter..     i don't even work for the company.. i just enjoy fixing cars...  nobody there even knows what i look like..   whats really funny.. i don't know what they look like either. or their names.. mostly..
one more thing...
find a scan tool that will do these gm systems..  they are available.. it will make you life working with cars easier..
i could not fix them easily without one..
please... copy and paste this link...
http://repairguide.autozone.com/znetrgs/repair_guide_content/en_us/images/0900c152/80/06/7e/6a/large/0900c15280067e6a.gif
then print it... keep it with your scan tool... so that you know what the readings should be when you are scanning through them... i tend to print copies..  hand them to techs with problems.. have them write in the cars actual readings on the print out..    sure makes it easy to figure out whats wrong them..
gettnlarge01
Posted: 02/20/10 03:49 PM
+1
WiCkEd94Z28
Posted: 02/24/10 12:27 PM
I'm having the same problem with my 94 Z28 LT1....Fuel pump works great...new filter..new fuel pump relay...new oil pressure sensor.....still same ol same ol...runs good for 15 to 20 and stalls out...before it stalls the RPM gauge jumps all over the place and sometimes it makes the fuel pump go crazy....I heard alot about ditributor(opti-spark) making this happen....theres alot of snow here atm so cant pull it in the garage and check that....so if you find somthing out plzz let me know because im having the same problem.....except when mine stalls out I can let it sit for about 5min and it will fire back up and run for another 10min..... It ran great before I ran it out of gas and put a new starter on tho...
Posted: 02/24/10 04:48 PM
did you read my posts above??
the module is most of a suspect in your description.. than anything else ...
the module is also easier to change first.. as long as you put the proper thermal grease under it to prevent it from burning out...
but it could be the optispark unit..    the optispark unit takes at least an hour if you are good to change...
po_choppa
Posted: 02/26/10 09:05 PM
MINE WASNT THE MODULE, I PUT A NEW 1 ON IT. I TRIED IT AGAIN TO. I PUT MY TIMING LIGHT ON THE NO.1 PLUG WIRE AND NO.3. IT RAN FINE AT IDLE FOR 5 MINUTES THEN IT STARTED TO MISS. NO.3 WAS THE WORST. SO BEFORE IT DIED OUT I PUT THE LIGHT ON THE COIL WIRE AND IT WAS MISSING TOO.
po_choppa
Posted: 02/26/10 09:06 PM
WICKED94, THATS EXACTLY WHEN MY PROBLEMS STARTED AFTER IT WAS RAN OUT OF GAS.
IM GONNA THROW ON A NEW COIL TOMORROW, IF THAT DONT WORK I WILL BE CHANGING THE OPTISPARK. I DO BELIVE THAT (OPTISPARK) IS MY PROBLEM.
Posted: 02/27/10 08:03 AM
got codes???????? its not hard to ***  these codes are listed for a OBD2 car.. not an obd 1.. i will see about codes for that...
http://www.underhoodservice.com/Article/40002/diagnosing_gm_lt1_v8_engines.aspx
text for everybody...    from link above
Diagnosing GM LT1 V8 Engines
By Dan Maslic
November 01, 2005
The Chevrolet LT1 engine is the second-generation (Gen II) design of Chevy's famous small block. The LT1 was fitted in Chevy's Corvette, Camaro and Caprice/Impala SS. This engine also was used by Pontiac for the Firebird, by Buick for the Roadmaster and by Cadillac for the Fleetwood. The LT1 was first available on the Corvette in 1992, followed by General Motors' F-body cars (Camaro/Firebird) in 1993 and the B-body cars (Caprice/Roadmaster/Fleetwood) in 1994. The Gen II engine was manufactured in two displacements, 350 cubic inches (5.7L) and 265 cubic inches (4.3L). The 265 cubic inch engine was only available on B-body cars. Interestingly, unlike other Chevy small block designs, the Gen II engine was never available in any trucks manufactured by GM.
Diagnosing 1992-'93 Gen II engines is a little different from 1994 and later Gen II small blocks in that the '92-'93 units are controlled by a unique ECM. The '92-'93 engines are controlled by the ECM carrying GM service #16159278. These ECMs utilize a PROM chip for vehicle calibration, and fire the fuel injectors in "batch-fire" mode. The ignition system is GM's Opti-Spark system. Engines from 1994 and later use the newer flash-style ECMs, which still use the Opti-Spark ignition system, but fire the fuel injectors sequentially instead of batch-fire.
It is important to note that the newer ECMs contain a removable "knock" module underneath a small access cover. The knock module supplies the ECM with the proper ignition retard rate when engine knock is detected. Typically, this module must be removed and installed in the new computer if the old unit is being replaced. Another important difference is the use of a MAF sensor on the '94 and later models. The 1992-'93 engines used speed-density fuel control, while the '94 and later models were equipped with a MAF sensor as well as a MAP sensor. The MAP sensor was retained for diagnostic reasons (to compare against the MAF reading and monitor EGR function) and to increase driveability and performance during the "limp-home" mode. The most common areas of failure on the Gen II small block lay in the Opti-Spark ignition system and the cooling system. Figure 1 shows the water pump and Opti-Spark ignition system components mounted on the front of the engine block.
The cooling system on the Gen II engine is a reverse-flow type where the water pump draws engine coolant from the radiator through the thermostat and pumps it up to the cylinder heads and down through the block. Aside from the reverse flow, the unique feature of the water pump is that it is shaft-driven as opposed to belt-driven. The water pump driveshaft is actually gear-driven off the camshaft drive gear. The shaft seal for the water pump is the most common point of failure in the cooling system, and it is usually rather obvious. Leaks may start small, but they get big in a hurry. When replacing a water pump on a Gen II engine, it is usually best to replace the shaft-drive coupling as well. If the coupling is even slightly out-of-round and not replaced, you may end up replacing the water pump a second time somewhere down the line.
The Opti-Spark ignition system employs a front-mounted distributor that is located below the water pump (watch those coolant leaks!) on the front of the engine block. The distributor is driven directly off the camshaft. Within the distributor are the high- and low-resolution pick-up sensor and timing disk, the rotor and cap. These used to be available as separate components, but are now typically available only as complete assemblies. The Opti-Spark distributor has a small vent for fresh air and, as such, may be susceptible to moisture problems if clogged or exposed.
Photo 1 shows the optical sensor and timing disk of a defective unit. The rust on this unit gives away the fact that the optical sensor suffered permanent water damage. The distributor transfers spark energy to the spark plugs from a single ignition coil and module (usually mounted on the front of the left cylinder head).
Figure 2
Figure 2 is a schematic of the Opti-Spark ignition system. Typically, when the Opti-Spark system fails (or is in poor condition), both the fuel injection and the ignition system are affected. The Opti-Spark system relies on two signals generated by an optical sensor pair and a timing disk. The sensors produce a high-resolution signal of 180 pulses per crankshaft revolution (for ignition system accuracy), and a profiled low-resolution signal. The low-resolution signal is profiled so that the ECM can determine the position of the #1 cylinder. The low-resolution profile gives a one-degree pulse every 90 degrees of camshaft rotation, separated by profiled pulses, which are approximately 6, 12, 18 and 22 camshaft degrees in duration respectively, and are also spaced 90 camshaft degrees apart. They occur in alternate sequence, first a short pulse, then a profiled pulse, followed again by a short pulse. Due to the alternating sequence of low-resolution pulses, the ECM receives a low-resolution pulse every 90 degrees of crank rotation.
By studying the timing disk in Photo 1, you can see how the timing slots are laid out. The distributor driveshaft is keyed to reduce the possibility of installing the unit incorrectly and creating timing errors in the signal. Generally, it is the high-resolution signal that is the first to fail. If this occurs, the ECM will generate DTC P0372, but the engine may still run, sometimes seemingly quite well. If the low-resolution signal is lost but the high-resolution signal is present, the ECM will generate DTC P1371. In this condition, the engine will not run, as there will be no fuel pump operation, injector control or ignition fire. The catch here is in the case of an intermittent high-resolution signal. It is possible to get a high-resolution signal that works intermittently, but generates no DTC. If the intermittent misses in the signal occur outside of the low-resolution pulses, the ECM may interpret that as a mechanical running problem and not an electrical/electronic failure of the sensor.
In cases such as this, the use of a scope is the only answer. By pinning the high- and low-resolution signals at the same time, you can easily determine if there is a fault in the sensor assembly. Since the sensors are of the optical type, you can expect a clean square wave signal measuring 5 volts peak-to-peak. If the engine keeps turning over, the high-resolution pulses should just keep coming in a steady square wave.
One other area of consideration when diagnosing Gen II-equipped cars is that of aftermarket performance enhancements. Aside from superchargers and similar heavy modifications that are rather obvious, there are other modifications that are quite popular and may cause diagnostic headaches, but may go unnoticed if you don't look carefully.
When certain driveability concerns or emission system errors occur, look out for items such as aftermarket performance headers and exhaust systems, fuel pressure regulators, ignition systems and (most troubling) performance software. Remember too, your customer may have bought his Gen II-equipped vehicle used and may not be aware of any high-performance goodies the previous owner may have installed and left on.
Exhaust systems aren't much of a concern except for 1996 and later OBD II vehicles, where the rear (post-catalytic) O2 sensor may have been tampered with or eliminated in favor of a high-flow exhaust system.
When a set of headers has been added, it should be verified that a contaminated O2 sensor (due to incorrect type or use of silicone) is not causing fuel trim errors. Checking O2 cross-counts with a scan tool or verifying O2 sensor operation with a scope may lead you to a quick fix for fuel trim issues.
The same goes for adjustable fuel pressure regulators. When adjustable pressure regulators are installed and set at too high a pressure, low-speed fueling may suffer with excessively rich mixtures that appear to straighten out as engine speed climbs. High-performance aftermarket ignition systems can cause running problems if not properly installed. Be wary of the routing of electrical harnesses when these ignition systems are used, as the high- and low-resolution signals of the Opti-Spark system are low-voltage/low-current signals. The Opti-Spark system signals can easily be affected by electrical noise and electro-magnetic interference if the wire harness is not properly shielded. Finally, have the customer verify whether or not any modifications have been made to the software calibration. Many aftermarket flash tools exist that allow the end-user a certain amount of adjustability of the fuel and ignition curves.
If you have a driveability problem or Check Engine light on your hands, it may be caused by improper software. Having the customer approve a re-flash of engine software may help in the diagnosis of a particular problem. Naturally, if high-performance software has been installed in the ECM, it may even be prudent to avoid doing any diagnostic work until the OE software is re-installed. After any problems are taken care of, customers can always have performance software re-installed if they so desire.
this linked article has even better pictures
http://www.underhoodservice.com/Article/59087/tech_feature_cooler_heads_prevail__pouring_over_gms_lt1_engine_and_reverseflow_technology.aspx
