123 Last
1968 327 4 bolt main
ReebokImpala
Posted: 10/06/09 06:53 PM
so i took my motor that some1 gave me and it turns out it is a 327 4 bolt . What are the odds of finding this engine. it is dated nov.3.1968. What should i do with it ? what kind of torque/hp app can i run with this for a 72 impala 4 door
Posted: 10/06/09 07:52 PM
how about the rpo numbers stamped on the front right deck????    it might be a really rare block and possible trading material ...    throw a casting number up also...
ReebokImpala
Posted: 10/07/09 04:13 PM
the casting number is 3932386. casting date is k308. Found some numbers saying 19z33290 and some others saying T01(or I)20HA. HAVE 2 PAIR OF HEADS . 3932411, B27-9 AND B25-9/// OTHER HEAD SAYS 3947041 ..
BLOCK ALSO HAS H40 STAMPED ON IT .. AND 386  636
                                       374  678.
Posted: 10/07/09 04:49 PM
It came factory with 275HP.
The 3947041 heads are decent heads.
How much power are you aiming for and then I could list a combo for you if you want.
ReebokImpala
Posted: 10/07/09 07:17 PM
i would like anywhere from 350-400. also , because my car is so heavy. I want a ton of torque. This car is most likely around 3000 maybe more lbs. its a 72 impala 4 door sports sedan.  I need good acceleration to get up and move in this boat. Daily driver and weekend cruiser.
Posted: 10/08/09 10:27 AM
Do you know what the car weighs.
ReebokImpala
Posted: 10/08/09 03:56 PM
1972 Chevrolet Impala
3,864-4,150 lbs
Posted: 10/09/09 01:47 PM
Do you plan on a complete rebuild.
ReebokImpala
Posted: 10/09/09 02:36 PM
yes, i do. the block is at the machine shop as we speak. still has . crank, cam, pistons. i have the heads. goin with new heads tho. dont think i will rebuild them.
Posted: 10/09/09 05:16 PM
If you do use one of the sets of heads you listed use the 041 heads they are decent heads.
What is your budget like and then I could list a combo of parts for you.
ReebokImpala
Posted: 10/10/09 12:49 PM
i have the most minimal of budgets. alot of work will be done by me researching and doing things myself. junkyard finds and such. what little money i do have to buy new parts i will. this is something i know will take awhile to get things just right. if i have to save for good parts i will. there is no rush on this project..
Posted: 10/10/09 01:44 PM
Do you know if the valves in the 041 heads are 2.02/1.60 or 1.94/1.50.
ReebokImpala
Posted: 10/10/09 03:37 PM
naw, i dont. most likely they r stock. what ever that is. how can i find out ? is there a way i can measure on my own ?
Posted: 10/10/09 05:10 PM
Yes use a measuring tape and measure the valves be sure to measure across the center of the valve if it is under 2 inches then they are 1.94 and if they are 2 inches then they are 2.02 valves.
ReebokImpala
Posted: 10/10/09 06:08 PM
when u say across the center do you mean width wise from the ports that are side by side or just one port at a time ? maybe if you have an illustration or can direct me to one to get the measurements right.
123 Last
