350 tbi build
9c1caprice9
Posted: 03/24/09 04:32 AM
i want to build a 383 i want to use 64cc vortec heads where r the tbi intakes that work wit vortec heads i want to use eagle 383 rotating assembly part num 356b13004l the heads part number is 809-12558060 i heard of a conversion kit to change from carb intake to tbi what kind of cam should i use flat or roller i want to use 670cfm holley tbi ideas  Ooo  Confused
chevelle83
Posted: 03/24/09 04:09 PM
If you upgrade the bottom end and leave the cam you will leave so much power on the table that it will barely be worth it. You can build a upgraded TBI engine, but the 383 will most likely need a upgraded throttle body for the fuel requirements. Most of the big cam makers have efi intended cams that will work fine.
Administrator
Posted: 03/25/09 05:45 AM
You can find a cam that'll be friendly for your computer. AS for the TBI unit and a 383, you need to find the TBI off a '92-'95 350 equipped truck (they were bigger than previous years) then add some 454 injectors.
9c1caprice9
Posted: 03/25/09 06:33 AM
i dont want 2 get to wild i have oil cooler trans cooler 700r4 trans its goin 2 b a daily driver
9c1caprice9
Posted: 03/28/09 06:28 PM
i want 2 build a nice strong engine at least 400hp or better im using vortec heads help me out on the rest
cathleen
Posted: 03/28/09 07:04 PM
with vortecs you can get 400hp and ftlbs of tq. with the 350. summit has vortec cast iron's on sale right now for 292! a piece!. definately they way to go over just about everystock head out. always worth 20-40hp alone. But scoggin dickey sells the modiffied L31vortecs that come ready for highlift cams for about 360 a piece. as the un moddified l31 are only good for about 420" lift stock. combine a fresh 350 with a vortec heads a vortec intake a healthy cam some headers and atleast 2.5" exhaust and some good flowmasters and you should get the 400hp. I'm sure you will have to upgrade the injectors,computer etc. 383 might be more of a hassle? it's just getting it to run right but that might yield another 70hp and ftlbs of tq over a 350 and should definately put you at the 450hp and ftlbs of tq. and get your tires smokin in the dry
cathleen
Posted: 03/28/09 07:05 PM
If you have vortecs already check you casting numbers to figure out what you have. some of the vortecs were prone to cracking and the other thing not being able to run a cam without mods. and I would use a tbi cam if possible
matt31
Posted: 04/10/09 03:54 PM
big question is it worth it to do all the mods to tbi system or convert to carb? i have a 1990 k2500 wanting to make 300bhp without spending to much.
matt31
Posted: 04/13/09 05:37 PM
can you run those vortec heads with there tbi after market intake? what cam do you recommend with these for good power?
homer4555
Posted: 04/13/09 07:27 PM
Im doing a similar build for my 87 chevy truck with a TBI, and I havent been able to find a TBI intake manifold to run with vortec heads.
9c1caprice9
Posted: 04/15/09 06:47 AM
im goin 383 eagle rotating assembly part number 356b13004l and vortec heads 64cc part number 80912558060 i want to use holley 670cfm throttle body i need to find a intake almost all of the intakes are for carbs i have heard of some kit to make the tbi work wit a carb intake what kind of cam should i use flat tappet or roller
homer4555
Posted: 08/08/09 04:54 PM
Im using a Comp Cams 258 Grind hyd. roller cam, .480 I/.488 E. It should have excellent low to mid range power and good fuel economy,  depending on your application it should be more than enough,  mines going in a full size truck/daily driver so it should be just right for my needs.
