Front Wheel Bearings
John-#010
Posted: 04/27/08 03:13 AM
I have a 2002 Camaro coupe.  When I turn corners, I am hearing the typical noise a front wheel bearing makes when it starts to wear out.  Straight driving is silent.  I need to replace front wheel bearings.
I have looked in my Chilton's Camaro book, but the front wheel bearings are not covered.  Does anyone know what is involved in changing out front wheel bearings??
Administrator
Posted: 04/28/08 06:07 AM
Pull the rotors off, pull the wheel seal, remove the bearings, swap in new ones packed with grease, the reinstall the rotor.
blk95z28
Posted: 04/28/08 07:41 AM
hey man i have a 95 z28 and mine did the same thing, you dont just get to change just the bearings you have to replace the whole hub assembly. it cost me about $100.00 from my local Advance Auto Parts store.
John-#010
Posted: 04/29/08 11:46 AM
One reply is right.  One is wrong.  The entire hub assy is removed.  It also cost me $100 at O'Riellys.  Very easy to change out.  Took maybe 1/2 hour.
Note:  Bearings are not removable
Administrator
Posted: 04/29/08 12:47 PM
My reply was wrong. I forgot the 4th Gens don't have the standard rotor assembly that the 1st/2nd/3rd Gens do, that the 4ths use a floating rotor design with a hub.
That being said, it's still easy to fix like the guys above said, just that the parts are a bit more expensive.
