LT1 Conversion to Carburetor
Perry
Posted: 12/21/06 08:21 AM
I plan to convert a LT1 engine out of an Impala SS to a carburetor and install in a 1940 Ford. I will eliminate the stock A/C and Alt brackets. Has anyone made this conversion? What A/C and Alt brackets did you use?
Any information will help!
Thanks Perry
runnerps
Posted: 12/29/08 08:01 AM
UPDATE!!!!
I have completed  the conversion of a LT1 to a carburetor. I now have a question.
The engine is running great. I used Alen Grove A/C & alternator componants.
I am now haveing a problem the engine breathing. I have GM value covers with the center bolts, a PCV hole and oil fill on the driver's side. A breather hole on the passanger side. I cannot find the right  combination for the engine to breath. Oil blows out of the passanger side value cover through the breather cap.
Any help will be appreciated.
Thanks Perry/runnerps
youngmoney
Posted: 04/22/09 11:23 AM
hey man i did the same conversion that u did but i put it in a 85 cutlass.The engine runs fine but i am having the same problem that u have with oil.Did u every find out any combination that worked?
need big help for such a small problem
thanks Youngmoney
Gabe9
Posted: 02/24/10 03:45 PM
Do i need a certain type of manifold intake,so the intake can fit on the heads properly?
