rear leaf spring
mkahl2001
Posted: 02/20/14 06:25 AM
im trying to find out what i need to buy for my car it has a lowering kit on it and i need the bushing for the bolt the runs threw the leaf in the rear all i have is a big hole and bolt running threw it looked at some kits but cant find anything that would look right can any one help with maybe a part number i should use to find what i need
Confused my car is a 92
JW72
Posted: 04/08/14 01:43 PM
1992 Corvette Rear Leaf Spring Lowering Kit ?????
    I am not aware of any lowering kits, but ......  Since 1963 all Corvette have a singular leaf spring that is transversely mounted from one side to the other, rather than from front to back.  This singular leaf spring is mount to the bottom of the third member and the ends attached to the rear hub carrier on each side.  There is a large long bolt, at the top is a flat metal washer and thick rubber washer, that attaches to the top of the rear hub carrier.  This is repeated at the bottom of the bolt that attaches to the transverse spring.  At the bottom of the threaded bolts is a flat metal washer and thick rubber washer, secured with a castle nut and cotter key.  There is nothing between the top of the leaf spring and the bottom of the trailing arms.  It easy to raise and lower the Corvette by adjusting these two bolts at the bottom end of the transverse spring.
    However, I think this is what you are looking for:
Http://www.ebay.com/itm/7-1020-Corvette-84-96-Rear-Spring-Cushion-Kit-/180956485832?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACorvette%7CYear%3A1992&hash=item2a21d8d8c8&vxp=mtr
Http://www.ebay.com/itm/C4-Corvette-Rear-Spring-Mount-Kit-12-Pieces-/350884022739?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACorvette%7CYear%3A1992&hash=item51b25149d3&vxp=mtr
Http://www.ebay.com/itm/Energy-Suspension-3-2123R-84-96-Chevy-Corvette-Red-Car-Rear-Spring-Cushions-/321360407711?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACorvette%7CYear%3A1992&hash=item4ad292ac9f&vxp=mtr
JW
Retired, raced Corvettes in SCCA for 20 years. Own a 1990 Corvette and a 1979 Corvette.
