headlight assembly in 1987 corvette
rangerlady
Posted: 08/02/13 06:56 AM
I have a 1987 corvette.  The passenger side headlight assembly will not go up. If I hotwire it, it will.  What can be the problem?
Posted: 08/02/13 08:06 AM
well.. hmm.. usually its a stripped gear.. preventing the headlight from coming all the way up..
here is the wiring diagram.. the lower section..
you could have a bad ground.. you could have a bad relay.. or a broken wire..
0900C1528008fda5
this should help.. and you will have to open the image above in a new window to view it completely..
