Abs active handling and traction control
xbme22x
Posted: 10/16/13 05:14 PM
Anyone out the know why I would get abs active handling and traction control service messages all come on at the same time while I was driving down the highway?
2003 z06
Posted: 10/16/13 06:14 PM
either plug in a OBD2 scan tool that has enough features to read all the codes... not all ***
or click the proper button on the dash board.. and the codes might pop up on one of the displays..
there is a way to perform that trick that posted just a few weeks ago...
xbme22x
Posted: 10/16/13 06:18 PM
Do you know what that trick was?
Not sure how to get through these forums to locate it
Posted: 10/16/13 06:46 PM
Chevrolet C5 Corvette
On-Board Diagnostics
This vehicle is equipped with a on-board diagnostic display feature capable displaying and/or clearing DTCs. By selecting specific buttons on the IPC, DTCs are then displayed on the IPC 20 character display unit. This feature allow DTCs to be read or cleared without the use a scan tool. When the diagnostic mode is first entered, the IPC will enter into an automatic display sequence and will display all systems that communicate on the serial data line. After each system is displayed, the IPC will display the number of DTCs (current or history) for that system. The manual diagnostic mode may be selected at any time during the automatic DTC display sequence by pressing any button on the DIC except the E/M 5. In the manual diagnostic mode, you can manually select what module is going to be displayed by pressing specific buttons on the DIC. In this mode, DTCs are only displayed for a specific module and will not proceed to the next until requested. Both diagnostic mode displays will also indicates if the DTC is a current DTC (malfunction present now) or a history DTC malfunction has occurred, but is not present now) with a C or an H, respectively. Diagnostics will automatically be exited if no DIC buttons are pressed for longer than 60 seconds.
Entering On-Board Diagnostics
To enter the Diagnostic Display function perform the following steps in order:
   Turn ON the ignition switch, engine OFF.
   Press the RESET button to acknowledge any warning messages present.
   Press the OPTIONS button on the Driver Information Center (DIC) and hold.
   While holding the OPTIONS button press the FUEL button 4 times within a 5 second period.
   System will first enter automatic display mode followed by the manual display mode.
Automatic Display DTC Mode
The automatic display feature allow you to read each module DTC display function in an automatic display sequence. Each system module DTC will be displayed for 3 seconds followed by a 1  second pause before the next DTC is displayed in an automatic sequence. If no DTC information is sent to the IPC from the system currently displayed on the IPC, the IPC will display NO CODES for that system. At any time during the automatic display function, the manual display feature can be activated by pressing any button on the DIC except the E/M 5 button. The E/M 5 button is used to completely exit the DIAGNOSTICS mode at any time. If there is a communications problem between any system, the IPC will display NO COMM when the IPC is trying to communicate with that system. When all DTCs have been displayed for all systems, the IPC will display NO MORE CODES for 2 seconds then will enter the manual display mode, waiting for manual mode operation.
Manual Display DTC Mode
The manual display feature allows you to manually select each module DTC display function. The manual mode will automatically be entered after the automatic DTC display sequence is complete, or can be entered at any time during the automatic mode by pressing any button on the DIC except the E/M 5 (E/M 5 button is used to exit the DIAGNOSTIC mode at any time). When the manual mode is selected, the IPC will display the MANUAL DIAGNOSTICS mode message for 2 seconds, or until any button on the DIC except the E/M 5 is pressed. After the MANUAL DIAGNOSTICS mode message is displayed, the IPC will display the first system abbreviation and quantity of codes stored for that system, then the IPC will wait for further instructions. The buttons on the DIC provide the following functions when operating the on-board diagnostic feature in the manual mode:
DIC Button Functions
DIC Button
Function
FUEL 1
Previous DTC
GAGES 2
Next DTC
TRIP 3
Previous System
OPTIONS 4
Next System
E/M 5
Exit Diagnostics
RESET
Clear DTCs
In both diagnostic modes, systems will be displayed in the following order:
   PCM (Powertrain Control Module)
   TCS (Traction Control System)
   RTD (Real Time Damping) (with F45 option)
   BCM (Body Control Module)
   SDM (Sensing and Diagnostic Module)
   IPC (Instrument Panel Cluster)
   RADIO (Radio)
   HVAC (Heater, Ventilation and Air Conditioning) (with CJ2 option)
   LDCM (Left Door Control Module)
   RDCM (Right Door Control Module)
   SCM (Seat Control Module) (with AAB option)
   RFA (Remote Function Actuation)
Clearing DTCs
To clear DTCs perform the following steps in order:
   While holding the OPTIONS button press the FUEL button 4 times within a 10 second period.
   Select the desired system to clear DTCs by pressing the OPTIONS 4 button (for the next system displayed) or the TRIP 3 button (for the previous system displayed).
   Press and hold the RESET button to clear DTCs for the system displayed.
Posted: 10/16/13 07:23 PM
by the way.. this almost always takes an advanced scan tool...
depending on the code..
usually.. a pair of techs take the car out for a test drive... just a normal drive.. not a drive it like you stole it test drive...
the passenger is monitoring the wheel speed sensors
checking the exact diameter of the tires..
the wheel speed sensors can be coated with brake rotor and pad debris..
the wheel speed sensor wiring could be damaged...
Samuel Jenkins
Posted: 11/07/13 07:03 AM
i have a 2002 vette with eletronic shocks and ride selection control options can the eletronic shocks be replaced with convential shocks ?
Posted: 11/08/13 12:20 AM
i don't know the answer for that..
but.. don't throw your old electro magnetic damping shocks away..
the magnetic fluid inside them is VERY EXPENSIVE...
i forgot what they call it..
oh yea..
http://en.wikipedia.org/wiki/Ferrofluid
http://www.youtube.com/watch?v=kL8R8SfuXp8
