ignition switch wiring
evs1
Posted: 01/23/12 02:04 PM
Hi all, somebody was working on my car who really shouldn't have been- they messed a few things up which i have sorted,and the only thing left is the wiring to the ign switch. could somebody tells me what goes where?
Vetteswitch
evs1
Posted: 01/23/12 02:05 PM
oh, by what i mean what color
Posted: 01/24/12 06:32 PM
i am guessing that you have somewhere between a 54 and a early 60s model..
there are wiring color changes between some years... so what year might really help narrow it down
i drop through here a few times each evening looking for new posts to answer .. so post.. and you will probably get an answer quite soon...
Posted: 01/25/12 01:51 PM
and chance of a year???
in 55.. there are 4 pink wires... a red,  a yellow, and a purple..
in a 60.. there are 2 pinks.. a red, a brown and a violet.
Posted: 01/25/12 06:01 PM
did you know.. that i was standing in an autozone one day... there was a long line.. the korean fellow in front of me had ONE spark plug. and six exhaust studs.. i noted the number on the ac delco spark plug.. it was a CR-43TS..  the line was still barely moving.. i pointed out that the spark plugs for his 4.3 astro van are behind the counter.. but the studs are hanging on the wall down the isle we are standing in front of... his jaw dropped.. ask me how i knew what kind of car he had.. i said.. i'm a professional mechanic.. i have to know what parts fit what car..   yea. but how did you know.... this is all i have..  i just smiled..  i think i blew his mind..  i did not tell him it was just an educated guess..  and that CR43TS spark plugs mostly fit astro vans..   they use then as they are in a pain of a spot to change..
037 CR43TS   037 R43TS
so i am really good at guessing about car parts...  but i don't want to get you the wrong info...
Posted: 01/26/12 07:43 PM
well.. i hope that you have gotten it fixed..   not gone off half plugged...
as in half plugged in that is..
briando
Posted: 11/20/12 12:07 PM
that might be burned out man. talk to a chevyguy and make sure before you reinstall
Posted: 11/22/12 01:13 AM
If it is burned out, there should be No continuity between any of the the switch poles. meaning they will all be an open circut. If thats the case. Those are marked A,B,C,D,E,F.
