high oil pressure
mgbasehit
Posted: 12/26/11 02:32 PM
oil pressure in my 05' vette just pegged to eighty psi on the instrument gauge, doesn't run any different, didn't modify anything, any explanation out there?
Posted: 12/26/11 04:23 PM
does the Gauge PEG after you turn the Key on.. but before you start the engine??? or ONLY after you start the engine...
the is the OIL pressure switch for your 2005 corvette..
change it.. verify the wiring to it is NOT damaged...
Thread Size: M16 X 1.50    this is a GASKET seal STRAIGHT thread.. NOT tapered pipe as is used on other oil pressure switches..
LS OIL Pressuresenderwiring
LS OIL Pressure Sender
be sure that if you try to find an oil pressure test gauge.. that you verify that you have the correct threaded adaptor.. the harbor freight versions don't have this 16 MM threaded adaptor..
there is a possibility that the in the oil pump bypass valve is sticking..
item 414 and 415  these are DEEP inside the engine behind the timing cover..
040427GM00 022
there is also an OIL filter bypass valve..
item 436
there is also an OIL cooler bypass valve ... shown as #4 on this picture.. open in a new window to view the right side..
0605221Y01 040
before you do anything.. check the TSB Titles over at alldatadiy.com
Posted: 12/26/11 04:47 PM
when i glanced at the TSBs i did not see any that might be an oil pressure issue.. but i might have missed it..
http://alldatadiy.com/TSB/10/051006fZ.html
read thru carefully...
these is at least one article i just saw in one of the magazines on replacing the LS crank driven oil pump
http://www.gmhightechperformance.com/tech/lsx_engine/0608gmhtp_ls7_camshaft_power_package_install/photo_39.html
Posted: 12/26/11 05:22 PM
oh...  speedway makes an adaptor for the LS motor oil pressure switch..
2268 - LS SERIES OIL PRESSURE SENDER ADAPTER Price: $10.99 EA
Item #: 1822268
Item Details: 16mm-1.5 Male to 1/8" Female
but.. but.. only ONE wire is used for the oil pressure switch.. the other two are probably for the fuel pump ...
http://www.speedwaymotors.com/LS-Series-Oil-Pressure-Sender-Adapter,20928.html
GM has an oil pressure tester.. that replaces the OIL filter..  to test the system fast and easy...
LS Engine OIL Pressure Test
briando
Posted: 07/26/12 04:02 PM
what happens if the oil pressure makes my http://www.mccarthychevrolet.com/new-inventory/pop a seal before i can fix it, what then?
