1970 Stingray Corvette,454,390hp, PLEASE HELP!!
Alonso4034
Posted: 04/27/11 02:09 PM
I am restoring this 70' corvette that has been sitting for 10-12 years. ive been doing pretty good on fixing it. just i have this part that i broke trying to take corosion off of it. it was on the drivers side on top of the valve cover. its rectangular and has a coil inside of it, has two screws on both sides of it. two wires went to it. one went to the coil and one to the distributor. i need help on what its called and where i can get a new one from
machine350
Posted: 04/27/11 04:09 PM
Maybe its a multiple spark discharge ignition you get a complete burn on each compression stroke meaning faster starts and more power. Iam not a 100% sure if thats what it is. Sounds like some kind of hot coil,does it look factory?
Posted: 04/27/11 05:59 PM
does your distributer have points and condenser inside...
or a rotating star (reluctor) and an outer star disc with arrows pointing inward with a big magnet and a coil of wire under it..( PICK UP COIL.)..   you might have the Transistor ignition .. and you might have broken the transistor ignition module...
take some pictures of it.. post them to photobucket.  com... and post the 4th link here in this text... so we can all see what you are talking about...
try photo bucket.. post the bottom link... it really does work...
Image Links
Alonso4034
Posted: 04/28/11 07:00 PM
what is your email, it will be easier to email the pictures to you??
Alonso4034
Posted: 04/28/11 07:03 PM
the way your describing doesnt sound right. the guy that posted below you sounds about right. if you put your email i can seend you a picture of it as well
Posted: 04/28/11 09:11 PM
this is what some of them look like....
don't throw it away... many are repairable or rebuildable...
Transistorignitionmodule
machine350
Posted: 04/29/11 02:18 AM
looks like a factory part going by the pic waynep7122
sent you . I was thinking aftermarket, hotter spark performance. Good luck on your build.
Posted: 04/29/11 06:32 AM
i am looking at his description... i don't have a clue of what he has... i am hoping he will post it at photobucket..   there are just so many things it could be...
some kind of spark booster... ?????
machine350
Posted: 04/29/11 11:44 AM
I thought he was talking about after market performance
ignition going by the description. Your theroy on the subject seems correct.
Alonso4034
Posted: 04/29/11 07:40 PM
ballist resistor is the part I was looking for. thanks for youlls help though
