Targa top on a 1993 vette Cracked
RayRay400
Posted: 11/25/10 05:51 AM
i have a targa top with a crack, it appear to be plastic not glass?
if it is plastic i was thinking about repairing the crack and painting it.
does anyone know what it is made of?
** I am adding this after the original post: looking at the Targa Top it appears to be made of a high quality plexiglass material.
i found this link to be helpful: http://ask.metafilter.com/45769/plexiglass-repair
but i need some input from those of you that have had a crack or know someone who has had one to reply to the post and let me know what you did and how you did it and the results of the REPAIR ???
RayRay400
Posted: 11/28/10 05:48 AM
it's pretty bad when you have to reply to your own posting.
i am not sure that all of them are made of arcylic, but some are. my roof is made of arcylic. so i will be repairing it and painting it myself and save somewhere in the neighborhood of $600. YA
mstershic
Posted: 02/12/12 09:23 AM
Does anyone know if the acrylic is available by itself and I can have it professionally installed in the frame.
Viscount
Posted: 03/10/12 11:58 AM
There are several companies out there that do this. Astro-tops comes to mind.
I would do a search for glass tops, etc.
I will say that if you decides to repair it yourself be sure to drill a stop hole at the end of the crack.
Posted: 03/11/12 10:23 AM
on your RPO label..
24S - ROOF COLOR,REMOVEABLE PANEL(BLUE);
64S - REMOVABLE ROOF PANEL COLOR,BRONZE;
C2L - ROOF PACKAGE,DUAL REMOVEABLE;
CC2 - ROOF,AUXILIARY;
CC3 - ROOF,SUN,REMOVEABLE PANELS(TRANSPARENT PLASTIC);
CF7 - ROOF,SUN,REMOVABLE,NON-TRANSPARENT;
VD1 - PROVISION OPTIONS,EUROPE(EXPORT);
the #numbers are the numbers on the GM parts picture..
#1
12370123 WINDOW PKG. Roof. WINDOW. Roof Panel.
WINDOW PKG,RF LIFT OFF(BLUE)(INSTALL .25) (12.810). Required: 01 For: Y07 CLEAR ROOF PANEL (CC3),DUAL REMOVEABLE ROOF(C2L),(24S) (1989-1996) (1993 - 1996).
#2
10284148 MOLDING. Roof Drip. Roof Panel.
MOLDING,RF LIFT OFF PNL/WDO RVL. Required: 01For: Y07 REMOVABLE SUNROOF(CF7),DUAL REMOVEABLE ROOF(C2L) (1984-1996) (1993 - 1996).
#11
10172311 WRENCH. Convertible and Hard Top. Roof Panel.
WRENCH,RF LIFT OFF PNL/WDO(RATCHET). Required: 01For: Y07 (1984-1996) (1993 - 1996).
#18
22112053 WEATHERSTRIP. Roof Panel
WEATHERSTRIP,RF LIFT OFF PNL/WDO SI BODY(10.710) - LH. Required: 01LHD. For: Y07 (1984-1996) (1993 - 1996).
#18
22112054 WEATHERSTRIP. Roof Panel
WEATHERSTRIP,RF LIFT OFF PNL/WDO SI BODY(10.710) - RH. Required: 01RHD. For: Y07 (1984-1996) (1993 - 1996).
#19
10283997 WEATHERSTRIP. Roof Panel
WEATHERSTRIP,RF LIFT OFF PNL/WDO RR. Required: 01
WEATHERSTRIP,RF LIFT OFF PNL/WDO RR(W/DEPRESSED SURFACE AT TOP CORNER). Required: 01
For: Y07 (1984-1994) (1993 - 1994).
#22
10268887 WEATHERSTRIP. Windshield Frame
WEATHERSTRIP,W/S FRM(12.810). Required: 01For: Y (1984-1996) (1993 - 1996).
#45
14065047 SEAL. Roof Panel
SEAL,RF LIFT OFF PNL/WDO(14.640). Required: 01For: Y07 CLEAR ROOF PANEL(CC3) (1984-1995) (1993 - 1995).
just to help out.. with a few numbers...
