64 brake system
buckbldg
Posted: 01/14/10 08:16 AM
I have a 64 with original power brakes. I am converting to a dual master cylinder (67)new, while maintaining the drum brakes. Do I need to install a proportioning valve or just hook up the lines - front bowl to front brakes, etc? And does the size of the brake line matter?  1/4 inch lines now    tom
Posted: 01/14/10 10:39 PM
i think this web site and supplier has some thoughts on this...
http://www.piratejack.net/Tech-Support/Typical-Brake-System-Configurations.html
might get you started...
this is what you might think about installing to split the front and rear system... ..
http://www.piratejack.net/Proportioning-Valves/PV67C-Corvette-1967-68-Proportioning-Valve.html
using that may allow you to use replacement lines that are prebent..
i think a bit of research is really called for...
there are some articles already published...  here is one that i just found..
http://www.vetteweb.com/tech/vemp_0204_dual_master_cylinder_brake_system_corvette/index.html
here is another about installing front disc and a dual master  on a 63/64
http://www.corvettefever.com/howto/153_0111_DISK/index.html
