RETAINED ACCESSORY POWER
SUNSETAUTO
Posted: 07/28/09 11:41 AM
I HAVE A 1998 C6 AND AFTER THE BCM GOES TO SLEEP WHEN USING ANY BUTTON ON THE KEY FOB OR LOCK OR UNLOCK DOORS WITH KEY THE RETAINED ACCESSORY POWER TURN ON UNTIL THE DOOR IS OPEN. I HAVE REPLACED THE BCM, AND TRYED DISCONNECTING BOTH DOOR MODULES AND SEAT MODULE (NO HELP).  ANYONE THAT CAN HELP PLEASE POST. THANKS
waynep712
Posted: 07/28/09 10:36 PM
wow... thats going to take some deep research..
i was looking at the left door wiring..
http://repairguide.autozone.com/znetrgs/repair_guide_content/en_us/images/0900c152/80/27/86/7b/large/0900c1528027867b.gif
i cannot see where the retained acc power on it.. and the other diagrams are not up right now..
is your OBD2 scan tool CAN enabled and have the GM specific program in it.. so you can look at other systems than emission control....????
i have not had time to check the TSBS..
but the first recall might have an effect on it..
Automotive Recall and Technical Service Bulletin Titles for 1998 Chevrolet Corvette V8-5.7L VIN G.
TSB Number & Issue Date      TSB Title
04006C FEB 06    Recall - Electronic Steering Column Lock System Defect
05081 FEB 06    Campaign - Steering Column Lock Warranty Extension
01044 JUL 01    Campaign - Electronic Steering Lock Malfunction
01-07-30-036H JAN 09    A/T Control - DTC P0756 Diagnostic Tips
00-00-90-002J JAN 09    Tires - Correct Inflation Pressure Information
05-03-10-020B JAN 09    Tire - Use Of Nitrogen Gas In Tires
07-08-64-022B JAN 09    Instruments - Unnecessary Park Assist Mirror Replacement
01-06-01-011E DEC 08    Gasoline Engine - Oil Consumption Guidelines
06-08-50-009C DEC 08    Restraints - Passenger Presence Sensing System Info.
00-03-10-006D NOV 08    Tires - Radial Force Variation (RFV) Info.
04-07-30-017B NOV 08    A/T - Revised Converter Check Valve/Cooler Line Fitting
03-03-10-007D NOV 08    Wheels/Tires - OE Tire/Wheel Characteristics
01-07-30-032E SEP 08    A/T - 4T65E Fluid Leaking From A/T Vent
00-00-89-027E SEP 08    Interior - Elimination Of Unwanted Odors
06-08-64-007A SEP 08    OnStar(R) - Analog Only Systems Information
06-08-111-004A SEP 08    Body - Exterior Emblem Discoloration/Blistering/Peeling
05-03-10-005D SEP 08    Wheels/Tires - Upsized Wheel/Tire Characteristics
08-08-49-011B SEP 08    Instruments - Speedometer Accuracy Information
02-08-42-001C SEP 08    Lighting - Headlamp Polycarbonate Lens Damage Prevention
08-08-46-004 AUG 08    OnStar(R) - Aftermarket Device Interference Information
08-08-44-026 AUG 08    Audio System - Refurbishing Radio Faceplates/Knobs
05-06-04-022E AUG 08    Fuel System - TOP TIER Detergent Gasoline (Canada)
03-06-04-060B JUL 08    Ignition System - New Spark Plugs & Gapping Info.
02-06-03-008D JUL 08    Charging System - Low Voltage Display/Battery Discharged
05-06-02-001A JUL 08    Cooling System, A/C - Aluminum Heater Cores/Radiators
05-03-07-009B JUN 08    Alignment - Specifications/Requirements/Recommendations
04-06-04-047H JUN 08    Fuel System - 'TOP TIER' Detergent Gasoline Information
08-08-64-011 JUN 08    Mirrors - Heated Mirror Defrosting Time
05-00-89-072B JUN 08    Engine/Fuel System - Oil/Fuel Additive Information
00-07-30-022D JUN 08    A/T - 4L60/65E, No Reverse/2nd or 4th Gear
99-04-20-002E JUN 08    Drivetrain - Driveline Clunk Information
08-07-30-027 JUN 08    A/T - No Movement in Drive or 3rd Gear
03-08-44-005H MAY 08    Audio System - Interference With Rear Defogger ON
08-03-10-007 MAY 08    Tires - Minimizing Damage to TPM Sensors
01-07-30-010C MAY 08    A/T - Torque Converter Replacement Information
01-08-42-001F MAY 08    Lighting - Exterior Lamp Condensation Guidelines
03-07-29-004E MAY 08    M/T - Operating Characteristics of Manual Transmissions
08-03-10-005 MAY 08    Wheels/Tires - Chrome or Chrome Plated Steel Valve Caps
05-06-03-002C APR 08    Battery/Charging System - Electrical Diagnostics Info.
02-06-03-009C APR 08    Electrical - Battery Charging Tips/Recommendations
00-06-01-012C APR 08    Engine - Use of 'Surface Conditioning Disks'
08-06-01-008 MAR 08    Engine - Accessory Drive Belt Noise Diagnostics/Tool
08-03-10-004 MAR 08    Wheels/Tires - Accessory Wheel/Tire Mounting/Balancing
08-08-51-002 MAR 08    Body - TPO Fascia Cleaning Prior to Painting
08-09-41-003 FEB 08    Restraints - Usage of Used/Salvaged/Imitation Components
02-07-30-052E FEB 08    Automatic Transmission - Fluid Cooler Flushing
05-00-89-078B FEB 08    Fuel System - GM Fuel System Treatment PLUS(R) Info.
04-06-01-029B FEB 08    Engine - Crankcase Flushing Information
06-06-04-035A FEB 08    Fuel System - E85 Fuel Usage Precaution
06-02-32-013A FEB 08    Steering - Power Steering Pump Replacement Tips
06-08-44-015A FEB 08    Audio System - Noise When Using Portable Playback Unit
00-08-48-005C FEB 08    Body - Vehicle Glass Distortion Information
04-03-10-012B FEB 08    Wheels - Chrome Wheel Brake Dust Accumulation/Pitting
01-05-23-001B JAN 08    Brakes - Rotor Lateral Runout Correction Information
99-08-52-005C JAN 08    Keyless Entry System - Characteristics of Operation
08-01-38-001 JAN 08    A/C - Refrigerant Recovery/Recycling/Equipment
04-08-50-006B JAN 08    Interior - Seat Cover Wrinkle/Crease/Crack/Burn Info.
05-06-02-002B JAN 08    Cooling System - DEX-COOL®(R) Coolant Leak Detection Dye
05-03-10-003C JAN 08    Wheels/Tires - Low Tire Pressure
99-09-40-005E JAN 08    Seat Belts - Seat Belt Extender Availability
04-03-10-001D JAN 08    Tires - Tire Puncture Repair Procedures
04-07-30-037D NOV 07    A/T - Dexron®(R)-VI Fluid Information
03-00-89-008D NOV 07    Body - Metal Body Panel Corrosion Protection
05-06-01-010B SEP 07    Engine - Sealant Usage/Procedures
07-07-30-024 SEP 07    A/T - Valve Body Reconditioning
07-06-01-016A SEP 07    Engine - Internal Noise/Damage After Oil Filter Change
07-08-45-002 SEP 07    Electrical - Aftermarket Fuse Warning
05-06-04-035C JUL 07    Fuel System - E85 Fuel Usage Precautions
99-08-64-016B JUN 07    Body - Use of Silicone for Weatherstrip Maintenance
00-06-01-026B JUN 07    Intake Manifold - Inspect/Replace After Engine Damage
06-08-43-003A JUN 07    Wipers - Performance/Cleaning Instructions/Maintenance
99-01-39-004B MAY 07    A/C - Odors In Hot/Humid Conditions
01-07-30-042E MAY 07    A/T - 2-3 Upshift or 3-2 Downshift Clunk Noise
05-08-51-008B APR 07    Body - Bumps or Rust Colored Spots in Paint
07-08-63-001 APR 07    Body - Polypropylene Energy Absorber Replacement
07-08-44-007 APR 07    Navigation System - Replacement Navigation Discs
02-08-42-004A MAR 07    Instruments - Reduced PRNDL Display Visibility
07-06-01-002 MAR 07    Engine - Revised Connecting Rod Bolt Torque
04-07-30-013B FEB 07    Engine, A/T - Shift/Driveability Concerns/MIL ON
06-00-89-051A JAN 07    Locks - Key Code Securtiy Rules & Information
06-08-46-007 DEC 06    OnStar - Analog-Only Systems Information
06-00-89-054 NOV 06    Warranty - Claims Submission
01-07-31-002B NOV 06    M/T - Hydraulic Clutch Bleeding Procedure Improvement
00-06-04-033B OCT 06    Emissions - OBDII I/M Readiness Testing
02-08-98-001C OCT 06    Body - Metal Panel Adhesive Bonding Information
06-03-10-010 SEP 06    Wheels - Changing Procedures/Precautions
00-06-02-006D AUG 06    Cooling System - Coolant Recycling Information
06-06-04-037 AUG 06    Engine Controls - MIL Function During I/M Testing
00-03-10-002D AUG 06    Wheels Chrome Wheel Chemical Staining/Pitting/Corrosion
06-01-39-007 JUL 06    A/C - Contaminated R134A Refrigerant
99-08-51-007C JUN 06    Wheels - Aluminum Wheel Refinishing Recommendations
04-07-30-037B JUN 06    A/T - Dexron®(R) VI Fluid Availability
03-07-30-043A MAY 06    A/T - Shift Lock Control Feature Function
03-04-20-006A MAY 06    Drivetrain - Rear Differential Fluid Leaks
06-08-45-004 MAY 06    Electrical - Instrument Panel & General Wiring Repair
02-08-48-001B MAR 06    Body - Urethane Adhesives for Glass Applications
06-03-10-004 MAR 06    Tires/Wheels - Wheel Weight Usage Precautions
02-06-05-004B FEB 06    Accessories - DTC's P0300, P1380, P1381
05-08-44-029A FEB 06    Audio System - Radio Knob Availability
04-07-30-028A JAN 06    A/T - 4T65-E Fluid Leaks From Reverse Servo Cover
04-06-04-051B JAN 06    Fuel System - Fuel Injector Maintenance Cleaning
05-03-10-019 DEC 05    Tires - Run Flat/Zero Pressure Tire Info./Service
99-08-51-001A NOV 05    Body - Paint-Less Dent Repair Recommendations
02-01-39-004B NOV 05    A/C - New PAG Oil
01-07-30-041B OCT 05    A/T - Diagnosing Fluid Leaks
02-07-30-024B AUG 05    A/T - Cracked Case Diagnosis
03-06-04-012A AUG 05    Electrical - Harness Connection Inspection
05-02-35-004 JUL 05    Steering - Revised Steering Column Service
04-08-48-001B JUN 05    A/C - Broken Rear Window Defogger Grid Detection
00-08-46-002A APR 05    OnStar(R) - Cellular Antenna Replacement Parts
99-09-40-004A APR 05    Restraints - Child Seat Top Teather Attachment Kits
05-03-08-004 MAR 05    Suspension - Revised Front/Rear Ball Joint Torque Specs.
03-05-24-001A MAR 05    Brakes - Wheel Cylinder Inspection Guidelines
99-08-46-001A MAR 05    OnStar(R) - Dealer Kits No Longer Available
01-08-46-004A MAR 05    OnStar(R)/Cell Phone - Integration
00-07-30-009A FEB 05    A/T - New/Reman A/T Identification
00-08-46-003B FEB 05    Instruments - GPS System Performance Degradation
03-09-41-003A FEB 05    Restraints - Air Bag System Diagnostics
01-01-38-006D SEP 04    A/C - R-134a System Flushing Procedures
04-07-31-005 AUG 04    M/T - Clutch Pressure Plate Wear Indicator Adjustment
01-03-10-009A JUL 04    Wheels - Plastic Wheel Nut Covers Loose/Missing
02-06-03-010A JUL 04    Battery - Parasitic Drain
04-06-00-047 JUN 04    Fuel - Top Tier Detergent Gasoline Information
04-06-05-007 JUN 04    Exhaust System - Intermediate Pipe Now Available
04-06-04-031 APR 04    Fuel System - Difficult Vehicle Refueling
04-06-01-013 APR 04    Engine - Serpentine Drive Belt Wear Information
04-08-50-005 FEB 04    Interior - Seat Back(s) Twisting
04-07-30-006 FEB 04    A/T - 4L65E, 4L60E, 4L60, 200-4R Oil Pump Spring
03-07-30-056 NOV 03    A/T - 4L60-E Oil Pump Identification
01-01-38-013A OCT 03    A/C - Unnecessary Compressor Replacement
02-06-04-022A OCT 03    Engine Controls - PCM Reprogramming/Data line Diagnosis
03-02-36-002 JUL 03    Steering - Revised Service Procedures
01-01-39-003A JUL 03    A/C - Catastrophic Compressor Failure Debris Removal
03-07-30-027 JUN 03    A/T - Oil Cooler Flushing Frequently Asked Questions
03-01-39-004 APR 03    A/C - Controls Intermittently Inoperative
03-03-10-004 APR 03    Tire Pressure Monitor - Grommet Availability
99-01-39-007B MAR 03    A/C - Automatic A/C Functional Description
03-01-38-001 MAR 03    A/C - System Sealers/Leak Detection Guidelines
99-07-30-017A FEB 03    A/T - Oil Cooler Flushing/Flow Check Procedures
03-04-20-002 JAN 03    Differential - Revised Output Shaft Seal Replacement
03-04-20-001 JAN 03    Differential - Revised Rear Axle Assembly Procedure
02-06-01-029 SEP 02    Engine - Needle Bearings Found Upon Oil Change
02-06-01-028 AUG 02    Engine - Crankcase Flushing Recommendations
02-07-30-028 JUN 02    A/T - Serial Number/Site Code Locations/Identification
02-06-01-026 JUN 02    Engine - Identification Information
02-06-04-023A JUN 02    Engine Controls - Spark Knock/MIL ON/ DTC P0332 Set
02-08-57-003 MAY 02    Body - Water Leaks to the Interior
01-07-30-023B MAR 02    A/T - 4L60-E Harsh 1-2 Gear Upshift/MIL/SES/CEL ON
02-06-01-008 MAR 02    Engine - New Prelube Tool
02-08-50-002 MAR 02    Seat (Driver's) - Movement on Acceleration/Braking
02-08-111-001 FEB 02    Tonneau Cover - Paint Is Wearing Through
99-00-89-019B FEB 02    Warranty - Parts Return Program Explained
02-07-30-003 JAN 02    A/T - New Design Reaction Shell Thrust Washer
01-02-35-008 DEC 01    Electronic Steering Column Lock - Inoperative
01-03-10-011 DEC 01    Tires - Sidewall Damage
01-06-04-044 NOV 01    EVAP System - Special Tool Usage
01-06-01-027 NOV 01    Engine - Cylinder Head Replacement Revision
01-07-30-029 OCT 01    A/T - Core Return Product Feedback Form
00-06-04-011A OCT 01    EVAP System - Monitor Strategy
01-00-89-013 SEP 01    RKE Transmitter - Correct Use of Labor Operation R4490
01-08-67-003 AUG 01    Convertible Top - Squeak From Rear Of Top
01-00-89-010 JUN 01    Diagnostic Worksheet - Usage
01-08-64-009 JUN 01    Doors - Rattle At High Audio Volume
01-09-40-002 JUN 01    Seat Belt System - Collision Replacement Guidelines
01-00-89-009 MAY 01    Key/Key Number/Security Chip - Replacement
01-07-30-021 MAY 01    Park/Neutral Switch - Connector Hard to Remove
00-03-10-003B MAY 01    Tires - Bumper To Bumper Warranty Coverage
01-07-30-012 APR 01    A/T - 4L60 E Revised Valve Body/Spacer/Gaskets
01-07-30-020 APR 01    A/T - 4L60E Valve Body/Spacer/Gasket Kit Reference
99-07-30-020A APR 01    A/T - Service Procedure Changes
01-08-44-005 APR 01    Radio Display - Error Code Diagnosis/Repair
01-02-32-004 APR 01    Special Tools - Power Steering System Analyzer
01-06-04-022 MAR 01    Fuel Gauge - Inaccurate/Erratic Readings
01-04-20-001 JAN 01    Rear Axle - Revised Set Up/Measurement Procedures
00-00-90-001 NOV 00    Suspension - Chassis Lubrication Importance
00-03-10-005 NOV 00    Tires - OEM Tire Replacement Recommendation
00-01-38-007 SEP 00    A/C Performance/Leaks - Diagnostic Procedure
00-00-89-021 AUG 00    Cross Line - Warranty Information
00-06-01-016 AUG 00    Engine - Aluminum Thread Repair Kits
00-08-67-002 JUN 00    Convertible Top - Cleaning and Care of Fabric
00-06-04-026 JUN 00    PCM - Returned Product Feedback Program
99-01-38-006A MAY 00    A/C - Refrigerant Recovery/Recharge Equipment
00-06-03-003 MAY 00    Battery - Testing and Replacement
00-05-22-004 MAY 00    Brake Fluid - Level & Filling Recommendations
00-06-04-021 MAY 00    EVAP System - Service of Connectors
99-00-84-021B APR 00    Warranty - GM Dealer Parts Procurement
00-08-64-004 MAR 00    Window Motor - Noisy/Inoperative
99-02-35-002 FEB 00    Steering - Revised Column Lock Wiring, Early & Late
99-09-41-004 JAN 00    Air Bag (SIR) On-Off Switch Kits, New Parts and Service
99-06-03-012 DEC 99    Battery - Testing & Replacement
99-08-45-005 NOV 99    Accessory Receptacle/Cigar Lighter - Inoperative
99-08-42-009 NOV 99    IP Dimmer Control - Proper Setting
99-06-04-053 NOV 99    PROM - Powertrain Control Module Reprogramming
99-07-30-021 OCT 99    A/T - New Solenoid Testing Kit
99-08-44-008 OCT 99    Cassette Player - Cleaning and Maintenance
99-06-02-017 OCT 99    Cooling - Radiator Repair/Replacement Guidelines
99-06-02-016 OCT 99    Instruments - Low Coolant Light Comes ON at Start-up
99-06-03-011 OCT 99    Warranty - Generator Replacement
99-00-89-016 SEP 99    Warranty - Labor Time Guide Updates, 09/99
99-08-42-005 AUG 99    Lighting - Loose or Missing Headlamp Door Bezel Plug
99-08-49-008 JUL 99    Chime - Sounds When Key is Removed From Ignition
99-08-50-010 JUL 99    Seat Back - Premature Leather Cover Wear
99-06-01-011 JUN 99    Engine - Second Design Connecting Rod Bolt & Torques
99-07-29-001 JUN 99    M/T - Squeak Type Noise from Shift Boot When Shifting
99-03-10-102 JUN 99    Warranty - OE Chrome Plated Aluminum Wheel ID
99-06-01-007 MAY 99    Engine - Accessory Drive Squeak
99-05-25-001 APR 99    Brakes - Revised ABS Diagnostic Procedure
99-06-01-004 APR 99    Engine - Revised Dimension for Rear Oil Gallery Plug
99-08-49-006 APR 99    Instrument Panel - Upper Surface Reflection
99-08-52-002 APR 99    Keyless Entry/Information Center - Inoperative
99-07-30-005 MAR 99    A/T - 4L60-E DTC P1870 Diagnosis
99-06-03-002 MAR 99    Battery - Insulator Replacement & Caution
99-06-03-001 MAR 99    Battery - Testing Equipment Explained
99-06-04-013 MAR 99    Fuel - System Service Kits & New `Break-Away Head' Bolts
99-08-49-002 MAR 99    Instrument Panel - Identification
99-06-04-009 MAR 99    Instruments - Revised Fuel Sender Replacement Procedures
83-81-34 MAR 99    SIR - Operating Vehicle with Warning Light On
99-08-50-002 MAR 99    Seatback Cover - Revised Removal Procedure
99-06-02-008 FEB 99    Cooling - Water Pump & Pulley Identification & Usage
83-63-10A FEB 99    Fuel Pump - Noise Coming from Pump or Fuel Tank Area
83-15-23 DEC 98    Roof Panel - Replacement Procedures
86-05-02 DEC 98    Warranty - Notice of Delayed Start Process
87-71-74 NOV 98    A/T - 1-2 Accumulator Piston/Outer Spring Replacement
83-32-10 NOV 98    Tools - Adjuster Locknut Wrench
83-32-09 NOV 98    Tools - Power Steering Bleeder Adapter
83-31-09 OCT 98    Alignment - Latest Available Specifications
83-17-04 OCT 98    Door Handles - On White Painted Vehicles Turning Yellow
76-02-02A OCT 98    Drivetrain - Recommended Axle Lubricant
83-83-15A OCT 98    I/P Cluster - Information on Replacing and Diagnosis
83-15-16 OCT 98    New Windshield/Glass Urethane Adhesive Caulking Kit
83-02-01 SEP 98    Crankcase Ventilation System - Revised Maintenance
83-81-32 SEP 98    PCM Connector - Information on New Service Kits
83-90-14 SEP 98    RKE/TPM Systems - Inoperative
87-61-27 AUG 98    Cylinder Head Bolts - Revised Torque Specifications
87-61-29 AUG 98    Engine - Oil Pressure Testing Tool
84-96-01 AUG 98    Entertainment Systems - Correct Labor Codes
83-90-12 AUG 98    Tools - Keyless Entry Transmitter Tester
80-05-03 AUG 98    Warranty - Parts Warranty Special Claims B and C
83-15-13 JUL 98    Body - Poor Front Fender to Door Fit/Appearance
83-66-07 JUL 98    Exhaust Muffler - Insulator Rumble Noise
73-15-12A JUL 98    Exterior Trim - Loose Lower Front Fascia Valance Panels
83-96-05 JUL 98    Radio Telephone/Mobile Radio - Install/Troubleshooting
68-05-02B JUL 98    Warranty - Courtesy Transportation Guidelines
83-90-08 JUN 98    Cruise Control - (W/Electro Stepper Mtr.) Diagnostics
83-15-11 JUN 98    Plenum Air Inlet Screen - Discoloration/Staining
83-96-04 JUN 98    Radio - Delco Exchange Reference
83-71-10 MAY 98    A/T - Park/Neutral Switch Connector Cannot Be Removed
83-15-06 MAY 98    Body/Frame - Tonneau Cover Noise Over Bumps
83-81-25 MAY 98    Convertible Top - Rear Window Defogger Inoperative
83-15-07 MAY 98    Door - Hiss Noise From Weatherstrip When Closing Door
83-15-05 MAY 98    Door Glass - Rattle
83-15-08 MAY 98    Door Glass - Waterleak Around the Blow-up Clip
82-05-02 MAY 98    Warranty - Request for Wholesale Authorization
82-05-05 MAY 98    Warranty Inquiry System
83-34-07 APR 98    A/T Mount - Clatter Noise in Passenger Compartment
83-96-03 APR 98    Audio - GM Sound Selling Programs
83-15-04 APR 98    Convertible Top - Clicking/Tick Noise in Interior
87-61-24 APR 98    Engine - Surface Conditioning Discs Precautions
83-82-07 APR 98    Headlight Door Bezel Plug - Loose or Missing
83-12-19 MAR 98    A/C Compressor - Bolt Torque Specification Revised
83-15-02 MAR 98    Body/Frame - Waterleak and Windnoise Diagnosis
48-05-01C MAR 98    Customer Concern Not Duplicated /Verified - Labor
83-83-07 MAR 98    Fuel Level Sensor - Replacement Procedure
87-65-10 MAR 98    PCM - Non Functional After Programming/No Start
83-64-09 MAR 98    Tools - Released for CS Generator Diagnosis
83-01-14 MAR 98    VIN Plate - Replacement Policy and Procedure
87-61-13 FEB 98    Accessory Drive Belt - Rumble Noise at Low Idle Speeds
72-05-09 FEB 98    Warranty - GM Dealer Empowerment Program
82-05-01 FEB 98    Warranty - New Vehicle/Replacement Battery
77-71-75 JAN 98    A/T - Product Updates/Production Changes, 4L60-E
73-90-23 JAN 98    Airbags - Frontal (SIR) ON-Off Switch Kits, Parts/Procs
72-01-01 JAN 98    Audio - Radio Exchange Reference
73-50-37 JAN 98    Brakes - Rotor & Hub Flange Cleaning Tool Revision
72-05-12 JAN 98    Suspension - Shock Absorber/Strut Replacement Guidlines
72-05-14 JAN 98    Warranty - Enhanced Sublet Repair Policy
72-05-13 JAN 98    Warranty - Repair/Replace Policies & Procedures
33-17-01A DEC 97    Exhaust System - Paint Peeling from Painted Muffler
48-05-02B DEC 97    Parts Expediting - Reimbursement Policy
72-05-11 DEC 97    Warranty - Rail Dust Removal & Chemical Spotting Labor
73-12-13 NOV 97    A/C - PureGuard 2 Operating Alert
23-50-05B NOV 97    Brakes - Rotor Warranty Service Procedure
62-05-02A NOV 97    Labor - Revised Operation Z1241/Personal Property Damage
72-05-04 AUG 97    Warranty - Guidelines for Claiming Windshield Replace
72-05-06 AUG 97    Warranty - Guidelines for I/M 240 Labor
72-05-05 AUG 97    Warranty - Guidelines for Using E0420 Wheel Replace
68-05-03 JUN 96    Warranty - Goodwrench® Service Lifetime Service Guarantee
89358 NOV 88    Battery - Diagnosis and Charging
