High Oil Pressure Reading
berry442
Posted: 05/16/09 02:44 PM
Running 80 mph on interstate--oil pressure guage rises to 76#--reads 62# at idle.  Oil is fine, all other readings are fine--Any ideas as to problem?
waynep712
Posted: 05/23/09 04:00 PM
do you have a high volume pump?????  a fresh rebuild????
what weight oil are you running????   i want some of it if i can get that kinds of pressures...
if the oil pump pressure relief valve stuck.. and i have seen them stuck.. the filter blows off the motor...
with that much oil pressure.. i might pull the distributer once in a while and check the drive gear and with a bright light examine the exposed gear teeth on the cam for wear...
important thing to know... if you install a high volume or high pressure pump...  or even when you install a replacement oil pump....  there is a oil pump intermediate shaft with a steel collar instead of the plastic collar... that the stock shafts have...  many parts stores have the melling version as a part number IS-55E...   other companys use similar part numbering systems..
at high pressure.. the only thing holding the intermediate shaft in place is the nylon piece...    7 to 10 bucks makes it a good deal when you have the pan and pump off..
QS03NY
Posted: 03/16/11 06:01 PM
It could be a bad oil pressure sending unit.
