2003 Automatic Tempature Control Light Bulbs
Ed.Faranda
Posted: 03/04/09 01:30 PM
I am having trouble with my ATC unit.  I did manage to find some information to repair the dimmed LED display, which I did and now works great.  But, most of the lights bulbs on the unit are burned out.  I looked at them, and they are nothing that I have never scene before.  No marking what so-ever on the bulbs or anything.
Does anyone know where to get these bulbs?  Or better yet, if they have an LED replacement for them....
I found a place on eBay that will do an exchange for the unit at $100.  But, I would rather save the money and do it myself.  I am pretty darn good with a soldering iron, and that is all it would take (once I have some replacement parts!).
vetforvets
Posted: 01/05/11 11:59 AM
I have an HVAC module that was replaced,The problem was it was bright at times and very dim at times .they determined it had cold solder joints.I have no idea on fixing it but would be willing to part with the whole box for 100.00
Posted: 01/05/11 12:28 PM
i ran across another thread needing the circuit board bulbs that come in twist in sockets from the back...
so you have
PC74 bulbs   is the larger size... or bulb number 2162NW
PC61 bulbs   is the middle size   or bulb number 5021NW
PC51 bulbs... is the smallest    or bulb number 4186NW
the NW stands for neo wedge which is a prepped bulb with a socket to fit into a keyed hole in the circuit board..
copy and click the link below.. you can see some pictures of it...
below is a copy of my post from the other forum..
there are several socket mounted bulbs....
here is one that is slightly smaller than the PC74
http://www.donsbulbs.com/cgi-bin/r/b.pl/i%7c14v%7c1.4w%7cnw%7ct1.5%7c10000h%5e5021nw~usa.html
I / 14V / 1.4W / NW / T1.25 / 10000H 4186NW USA
I / 14V / 1.4W / NW / T1.5 / 10000H 5021NW USA (this bulb)
I / 14V / 1.4W / NW / T1.75 / 10000H 2162NW USA
I / 14V / 1.4W / NW / T1.75 / RELAMPABLE PC74R USA
I / 14V / 1.4W / NW / T1.75 PC38 USA
I / 14V / 1.4W / NW / T1.75 PC74 USA
the T1.25 and T1.5s are smaller than the T1.75 bulbs..........................
the T1.25 is a variant of a PCH51 8
I/14V/0.04A/PCB/T1.25
I/14V/0.04A/PCB/T1.25/16000H
PC-H-51-6
PC-H-51-7
PC-H-51-8
PC-H51-6
PC-H51-7
PC-H51-8
PC/H/51/6
PC/H/51/7
PC/H/51/8
PC H 51 6
PC H 51 7
PC H 51 8
PCH51-6
PCH51-6/14V/0.04A
PCH51-7
PCH51-7/14V/0.04A
PCH51-8
PCH51-8/14V/0.04A
PCH51/6
PCH51/7
PCH51/8
PCH51 6
PCH51 7
PCH51 8
the T1.5 bulb is going to be a variant of of a
I/14V/0.04A/PCB/T1.5
I/14V/0.04A/PCB/T1.5/16000H
PC-H-61-6
PC-H-61-7
PC-H-61-8
PC-H61-6
PC-H61-7
PC-H61-8
PC/H/61/6
PC/H/61/7
PC/H/61/8
PC H 61 6
PC H 61 7
PC H 61 8
PCH61-6
PCH61-6/14V/0.04A
PCH61-7
PCH61-7/14V/0.04A
PCH61-8
PCH61-8/14V/0.04A
PCH61/6
PCH61/7
PCH61/8
PCH61 6
PCH61 7
PCH61 8
hope this helps...
