123 Last
CROSSFIRE TO CARB.
kc5nqx
Posted: 03/01/09 07:34 AM
Stile waiting for a repley guys come on help help help
regebler
Posted: 03/01/09 02:24 PM
My C4 RUNSEXCELLENT EXCEPT FORTHE LOUD exhaust .No trouble at 84 K miles engine runs a little hot at times.punched her out this week 110 MPH started tobreak up abit so I let off.
kc5nqx
Posted: 03/01/09 02:27 PM
hey guys any help? please
kc5nqx@yahoo.com
kc5nqx
Posted: 03/01/09 07:13 PM
I will type it again sytem is trashed i bought this car after 5 differnt people tried to fix it  ecm gone missing not in the car half the wiring harness cut dirt darbers in the tbi's Its junk i have a 2701 intake bolted on rite now with a elderbrock 1406 carb what part number for drop down filter, Do they make a i inch filter can you drop the motor mounts with litlle work ? anybody or will the hood close and be danndy??
severance.dave
Posted: 04/03/09 07:13 PM
SORRY TO HEAR THAT SO MANY OF YOU ARE UNHAPPY WITH YOUR CFI. I OWN AN "84" WITH 165000 MILES ON IT AND FOR 205HP RUNS LIKE A CHAMP.I DONT KNOW IF ANY OF YOU MISSED WITH THE THROTLE BODIES BUT I WAS TOLD NOT TO LET ANYONE TOUCH THEM UNLESS THEY NEW EXACTLY WHAT THEY WERE DOING BECAUSE ONCE THEY ARE MESSED UP GOOD LUCK GETTING THEM RIGHT.I HATE TO SEE YOU CHANGE OVER TO CARB BECAUSE THAT IS NOT WHAT THESE CARS ARE ALL ABOUT AND I HATE TO SEE IT WHEN SOMEONE HAS MODIFIED A CORVETTE FROM ORIGINAL.MAY BE YOU SHOULD JUST TRY AND SELL IT AND BUY AN "85"
Warp2
Posted: 04/04/09 06:22 PM
I did it and heres how. Get a good quality FP regulator, make sure it has a return hole it otherwise you will burn up your intank pump, 6 LBS is the magic number for the carb. Edelbrock only makes one intake manifold that will fit under a 82 stock hood. Pick up a good HEI vacum advance distributor. Use 81 throttle linkage. Jerk the computer out from in back of the drivers seat. On the firewall under the Black plastic cover is all the wireing for that god awful system. Cut em all except the black ones, send them to ground, frame preferably. If you have any questions feel free to give me a shout.
Mark
509 965-6275
daddio32
Posted: 05/13/09 06:53 PM
I HAVE AN 84.  GOT IT OUT FROM UNDER A TREE(fALLEN)
I PUT A COMPUTER AND IGNITION MODULE + PLUGS, WIRES, CAP AND BUTTON.  IT RAN FINE FOR A FEW WEEKS.
PULLED ABOUT 98 IN 1/4 MILE
NOW IT RUNS LIKE ITS OUT OF TIME
CHECKED WITH 1PISTON AT TOP, MARK SEEMS TO LINE UP AND THE ROTOR BUTTON IS POINTING AT #1 PLUG WIRE ON THE DISTRIBUTOR CAP.
ANY SUGGESTIONS???
daddio32
Posted: 05/13/09 07:15 PM
I CANNOT FIGURE OUT HOW TO POST MY OWN THREAD
rickgalvez
Posted: 06/15/09 08:55 PM
HI guys long time for me being on this forum, Because I sold my 84 Vette.
Very Nice C4 Vette.
Good Luck to all 84 Vette owners looking to switch over from CFI to Carb.
Thanks again
1976 Corvette Stingray #s Matching
1984 Corvette C4 CFI to Carb
waynep712
Posted: 06/16/09 01:03 PM
i seem to recall that there are LOW PROFILE air cleaners available...  they fit tight down over the top of most holley carbs..   look for ones with dents for the center hung float bowls ..
K&N air filters makes some with only 2.75" inches over the air filter mounting ring...
http://www.knfilters.com/Racing/14inch.htm
i had  a factory version on an late 60's or early 70's big block chevy..
you might be able to get lower than that by going to a race carb without a choke horn...  but you have to know how to start it cold and maintain a fast idle till it gets warm...
jamwgm
Posted: 07/14/09 12:20 AM
my crossfire has already bin changed to an edlerbrock carb but was done befor i got her. and the fuel injection harness was never taken off i dont think they did anthing to it but swap the injection for the carb it runs  but begins to stall when i try and punch it.i want to change the one it has but i dont know what parts i need
88needs2win
Posted: 10/04/09 06:52 PM
Hey everyone. I have an 84 that was converted to an Edelbrock carb/intake setup. For under hood clearance, I used a Mr. Gasket air cleaner, part #4339. It's a low profile cleaner that only raises 2 inches above the carb. Fits perfect. The air cleaner was around $46 from Summit Racing. Oh, and it's a 14 inch one, too.
valsarth
Posted: 10/15/09 04:19 PM
Hey guys i just bought a 72 mach 1 with a built engine
its bored 30 over
forged pistons
chromemoly rings
4 valve heads
700 cfm holy double pump carb
crane cam
edelbrock medium rise mani
hooker headers
flowmaster dual exhaust
ram air ,i would also like to recommend Generic Viagra  for people like myself that have intimacy issues
Posted: 10/15/09 11:36 PM
i can understand.. that if you only have a 72 mustang.. that you would need assistance.. in that area...
but the rest of these guys have Corvettes.. they Don't need assistance..  except for the guy with the 4 door vette.. as he could get more enjoyables in the car with him.. so after an evening drifting... he might need some assistance..
buffyzoie
Posted: 12/06/09 07:17 PM
Hello.
my friends and I swapped the old motor to a 350 with a holly 750 double pumper carb, elderbrock intake, whitch raised the motor. There was a problem with getting enough air to the carb. I put on a hood scoop old style but I had to cut a hole in the hood to make it fit. It looks cool and works very good. no sputters. start offs are good. You have to watch out because a small push on the gas makes it take off. It takes a little practice but once you get the feel. WOW watch out.
To answer your question. It is possible and worth the effort. It is a rocket. Happy birthday to all you 1984 corvette ownwes "no emmission tests" in Ga.I say do it. it blows away the the original motor. The only differance is that you have to add a ramair intake and mold your hood.
sam
123 Last
