What is your preferred method for skip-shift elimination?
presidential
Posted: 11/17/06 07:38 AM
Did you buy the module or did you have it programmed out?
I'm curious to see what method everyone took on this minor nuisance.
Craig
garyus62
Posted: 04/16/08 05:46 PM
Have it programmed out if you are having a tune up the near future.
TechLine
Posted: 07/28/08 02:42 PM
The best way to eliminate skip shift problems is with programming. But-- rather than simply turning skip shift off, have it programmed to be active only above a certain engine coolant temperature. That way, if you don't notice that the temp gauge needle has entered the "red zone", you'll get a wake up call when the transmission suddenly wants to do the "One-to-Four Boogie". Under all other conditions, skip-shift will be missing in action.
QS03NY
Posted: 03/16/11 04:55 PM
I seldom shift into second at less than twenty miles per hour so it has never been an issue that caused me any problems.
