Cam Choice / Stall Choice
deemann
Posted: 05/07/14 10:09 AM
1969 Chevelle
3.73 rear gears  12 bolt posi-trac
350 - 4 bolt main 2 piece rear main seal
Edelbrock EStreet Aluminum Heads   2.02/1.60   9.1:0 Compression
Edelbrock RPM Air Gap Intake
Roller Rockers
Edelbrock AVS Thunder 650cfm carb
Turbo 350 transmission
Want:  Good driver with plenty of low - mid end torque   5,500 will be max RPMs I will run.
Cam Choices:  Lunati Voodoo #10120702  219/227  .468/.489  112/108
OR   Lunati Voodoo #10120703   227/233  .489/.504  110/106
I want my power brakes and will be repairing the factory AC.  I also have a choice between a 1,800-2,100 stall   OR   2,000 - 2,300 stall
Thanks.
Posted: 05/07/14 08:45 PM
If you are mainly looking for street performance and good vacuum  the milder cam should be your choice. I would not go over the 2000-2300 stall either.
