68 camaro disc brake conversion
ldickersonc
Posted: 08/01/12 04:50 PM
Want to do it, at least the front brakes.  Who are the go-to manufacturers?  I'd love made in the U.S.A., but I want some quality stuff more than anything.  Who's done it? what should i look out for when buying?
zman123
Posted: 08/02/12 06:46 AM
What is better than Made in USA chevrolet? go to your local wrecking yard for disc brakes on your Camaro. I used 74 Nova brakes on mine everything bolts right up. It's a simple swap.
camaroman6809
Posted: 08/02/12 12:52 PM
I put Aerospace Componants on all 4 corners. Been really happy with the performance and looks.
FANTM58
Posted: 03/30/14 08:53 PM
Check out chassis works , they have Will Wood products
Good stuff !!
Born -n- raised in Denver, Co
Gear Head for life !!
Posted: 03/31/14 07:53 AM
You can get the Parts cheep at the Salvage yard 100.00 or All New From Speedway for 4++.00-to 699.00 for 12"and larger,then you can start buying Larger calipers Too. I see a lot of Ads from Chevy classic parts or Classic Chevy Parts.You'll need a new Master and A porportioning Valve, but it is Simple, the Hard Part Being removing Old Parts without Damaging stuff you will want new rubber hoses and being adept with a tubing Bender and flare tool is Helpful,Brake rod to master may get Raised to upperhole on brake pedal,you don't need as much Leverage with Power.
Posted: 03/31/14 12:09 PM
I forgot to mention when you get to the larger rotors/12" and larger it becomes nessary to use the Larger wheels/17" up. A proper set up with Factory Sized Brakes will put the Bumper on the Ground.
