my Build
Herman Perkins
Posted: 03/22/14 01:31 PM
Hey guys, I just built an engine for my 89 chevy short bed step side and would like input please. this is what I've thrown together.   1969 corvette 350 standard bore, standard crank, 1971 327 double hump big valve 303 heads, crane 588 cam, crane roller rocker system, weiand single plane spread bore intake, with holley 700 cfm carb. accel high energy ignition system with the new E-3 plugs.  any comment positive or negative greatly welcomed.
shyrgfuh3
Posted: 03/22/14 01:40 PM
well since you already built it the only comment i have is to run it. most people ask for input prior to a build.
also, how did you run a 44 year old block with a std bore?
if your compression is less than around 9.5 - 10.0 it is not optimal.
i have never heard of a crane 588 cam, what is it? If you mean it has 588 lift your truck will never move unless you nave around 5.00 gears in it.
why do you want a spread bore intake?
why do you want a single plane intake?
Posted: 03/29/14 08:00 PM
Was this a build using only parts that were already laying around? No offense meant but it sounds like you had a bunch of parts collecting dust and decided to put them together. The main thing is to enjoy your creation.
