Exhaust question.
smittysmith
Posted: 07/18/13 06:14 PM
Just wondering if stock 305 ex. manifolds would fit on a 350 with vortec heads.Any and all advice welcome, and thanks in advance.
                                             Bob.
Posted: 07/18/13 06:33 PM
I going to say yes because both manifold look the same but you should look at the exhaust port shape to make sure they are the same.
smittysmith
Posted: 07/19/13 05:32 AM
Thanks Scott. I thought they should,but I don't have the 350 yet. I will check when I get it. If it looks like the flow will be impeded in any way, I'll probably go with some headers. Thanks again, Bob.
Posted: 07/19/13 07:28 AM
one thing...
there are 6 bolt exhaust patterns on SBC motors..
there are 7 bolt exhaust patterns on SBC motors.
there are also 8 bolt patterns on SBC motors..
-o0o--o00o--o0o  six bolt
oo0o--o00o--o0o  seven bolt pattern
oo0o--o00o--o0oo eight bolt pattern.
one has to look at the gasket face of the exhaust manifolds..
the passenger side usually is where the 7 bolt pattern is found..
on the gasket face.. of a 7 bolt exhaust manifold.. you will see this pattern.
o0o--o00o--o0 o    notice the gap. that would show up near the back of the head on the passenger side..
if you end up with 6 bolt heads... and have a 7 bolt exhaust manifold.. enginequest sells a 1/4" thick adaptor plate with one counter sunk location next to the gap. so you can use a 7 bolt manifold on a 6 bolt head.. #AH034
!Bdw2sewbwk~$(Kgrhqeh Dserer0u9tubk4jis7pkq~~ 12
smittysmith
Posted: 07/19/13 08:33 AM
That is valuable information!Much appreciated,thanks Wayne.Bob.
