Trans not engaging
bschevyk10
Posted: 07/06/13 09:27 PM
I have a th350 that isn't engaging or moving the truck when I put it into gear. I replaced the engine and when I pulled the engine I also pulled the trans and when I did I didn't cap the end of the trans and that was a lesson learned. Anyways I filled the torque converter up before installing and I have now dumped 10 quarts of trans fluid into it and its still not engaging and when I put it in park it grinds a little bit not real bad or loud but it shouldn't grind at all. Any ideas as what to do or what's wrong? Thank you
dond1965
Posted: 12/07/13 06:09 PM
the shift linkage is not functioning properly. probably needs to be adjusted and or tightened. sorry i couldnt answer earlier.
