Locked Thread Sticky Thread
How To Choose The Right Street Cam
Posted: 12/16/13 07:04 PM
How to Choose the Right Street Cam
Not so long ago, the bigger is better philosophy reigned supreme regarding camshafts. The result was overcammed engines that sounded great and could crank serious top-end power, but were not very streetable and couldn’t idle to save their lives.
But thanks to modern cam technology, you can come pretty darn close to the Holy Grail of street bumpsticks—cams that make high rpm power, have good low-end torque and drivability, decent vacuum for power brakes, and that loping idle we all love. Camshaft theory is a complex subject that can take a book-length article to explain. We’re going to concentrate on the basics you’ll need to know to choose a good street cam.
Lift and Duration
Lift and duration are the primary factors that determine a cam’s profile. Lift is the amount a cam lobe actually moves a valve off its seat, and is measured in fractions of an inch. Duration is the amount of time a cam keeps a valve off of its seat, measured in degrees of crank rotation.
Lift and duration combined determine total open valve area—the space available for air and fuel to flow into and out of the combustion chamber. The more valve area open to flow, the more power an engine can theoretically make. The trick is to “size” a cam to optimize valvetrain events for your particular engine combination and vehicle.
Cam Sizing
Virtually every cam maker uses duration to rate camshafts. When someone talks about a “big” cam, they are referring to cams with longer duration. This keeps the valves open longer, increasing midrange and top-end power at the expense of low-end torque. A shorter duration cam does just the opposite. Because it doesn’t keep the valves open as long, a smaller cam boosts low rpm torque and drivability. There are two ways to measure duration:
Advertised Duration is the figure you usually see in the cam ads and hear about at those late-night bench races. The problem with advertised duration is cam makers use various methods of measuring it, making it difficult to compare cams from different makers.
Duration at .050 measures duration at .050 inches of valve lift. Since all cam grinders use this measurement, it’s a much more accurate way to make a comparison. Two cams may be very close in advertised duration, for example, but make peak power at different rpms. Summit Racing uses duration at .050 ratings to help you better compare the wide variety of cams it carries.
Lobe Separation Angle
Lobe Separation Angle, or LSA, is the number of degrees that separate the peak lift points of the cam’s intake and exhaust lobes. LSA helps determine the cam’s behavior; you can take a given set of lift and duration figures, change the LSA, and get cams with vastly different  characteristics. Generally, a cam with wider LSA (112-116 degrees) offers less overlap between intake and exhaust opening and closing events. That translates into a wider rpm range, better idle quality, and higher engine vacuum, but at the cost of less torque at low and midrange rpm. A cam with a narrow LSA (104-108 degrees) offers greater low and midrange torque production, but with a narrower operating range, a choppy idle, and less engine vacuum.
For the street, you want a cam that offers a compromise--decent idle quality, respectable vacuum for operating power brakes and such, and good overall power production. separation. Again, much depends on the overall engine combination and intended use, but as a general rule, cams with a 110 to 112 degree LSA offer good power and decent street manners.
Flat Tappet vs. Roller
Now that you have an idea of what lift and duration are, let’s muddy things up by comparing flat tappet and roller lifter cams. Flat tappet cams use a lifter with a slightly curved bottom that slides against the cam lobes. Virtually every V8 engine built before the late 1980s came with a flat tappet cam; they are reliable and relatively inexpensive. With literally hundreds of profiles to choose from, finding a good flat tappet cam for your street car is not difficult.
Roller cams are hardened steel cams that use lifters with a roller, or wheel, that rolls over the cam lobes. This design dramatically decreases valvetrain friction and wear, and allows designers to create profiles that offer more lift without increasing duration. That means a roller can make more midrange and top end power than a flat tappet cam of the same duration without sacrificing bottom end power. If you need proof that roller cams are better, ask the OEMs what they put in their engines nowadays.
Hydraulic or Solid?
Flat tappet and roller cams for overhead valve engines are available with hydraulic and mechanical lifters. Hydraulic lifters are self-adjusting; they use an oil-damped, spring-loaded plunger to help maintain valve lash (the distance between the valve stem and the rocker arm tip). Hydraulic lifter cams are quiet, require virtually no maintenance, and transmit less shock to the valvetrain. Their main drawback is a tendency to “pump-up” (overfill with oil) and cause the valves to float, or stay open too long, at high rpm. Valve float kills power, and can lead to engine damage if you keep your foot planted in the throttle.
Mechanical, or solid, lifters are not self-adjusting. They rely on a properly set up, adjustable valvetrain to maintain proper valve lash. Because solid lifter cams are less susceptible to valve float at higher rpms, they are ideal for more radical street and racing profiles. The price of running solid lifters is periodic adjustment of valve lash and increased valvetrain noise.
Overhead Cam Considerations
Overhead cam engines, like Ford’s 4.6 and 5.4 liter Modular V8s, follow the same rules regarding cam selection as overhead valve engines. The primary difference is how valve lift is determined. Overhead cam engines don’t use rocker arms, so there is no multiplication effect to increase valve lift (cam lift x rocker arm ratio = valve lift). Thus, cam lift and valve lift are the same.
The only way to increase lift with an overhead cam is to reduce the diameter of its base circle (the rounded bottom portion of the lobes). Changing the base circle increases valve lash as well, requiring the use of taller lash caps on the valve stems to maintain proper valve lash. This is a fairly involved process, which is a big reason why you’ll see many street cams for overhead cam engines with various duration figures but the same lift number.
Information, Please
Your sales rep or cam maker will need to know the following parameters to help you get the right cam grind for your particular vehicle and engine combination:
Vehicle Weight: You can run a bigger cam in a lightweight vehicle because less low-end torque is necessary to get it moving. Heavy vehicles need cams that emphasize low-end power.
Rear Axle Gear Ratio and Tire Size: If you have a bigger (numerically higher) axle gear ratio, you can use a bigger cam. Lower “economy” gears work better with a mild cam that makes power at low rpm. Tire height is important because it helps determine the final drive ratio.
Transmission Type: Cams for automatic transmissions have to work over a broader rpm range.Manual transmissions can tolerate a bigger cam biased to making peak power. The cam’s powerband should match torque converter stall speed or clutch “dump” rpm.
Engine Size and Compression: A cam’s profile is affected by displacement. Most cam descriptions for small block Chevys, for example, are based on 350 cubic inch engines. Put a cam in a 383 stroker and it will act like a milder grind. The more duration a cam has, the more compression is needed to maintain proper cylinder pressure at low rpm.
Airflow: Your cam needs to work within the airflow capabilities of the engine. The airflow characteristics of thecylinder heads (amount, intake/exhaust ratios, port work, etc.), induction system, and exhaust system are all factors.
Power Adders: Superchargers, turbos, and nitrous oxide require special cam profiles to take advantage of the extra power potential. In general, cams made for use with power adders are ground with wider lobe separation to take advantage of the extra cylinder pressure.
Rocker Arm Ratio: Going to a larger rocker arm ratio increases valve lift on overhead valve engines. The cam should be tailored to work with your specific ratio to avoid slapping valves into pistons or trashing valve springs.
Cam Comparison: 5.0L Mustang
Let’s compare two popular hydraulic roller cams for a 5.0L Fox-body Mustang that specs out as follows:
•3,400 pound vehicle weight, 5-speed, 3.73 rear axle gear
•306 cubic inch small block, 9.5:1 compression with EFI, aluminum heads, shorty headers, and cat-back exhaust
Cam One: Ford Racing X303
(Part Number FMS-M-6250-X303)
Advertised Duration: 286 degrees intake/exhaust
Duration at .050: 224 degrees intake/exhaust
Valve Lift (with 1.6 rocker): .542 inches intake/exhaust
Lobe Separation: 110 degrees
Powerband: 2,500-6,200 rpm
Cam Two: Comp Cams Xtreme Energy OE Roller 35-514-8
(Part Number CCA-35-514-8)
Advertised Duration: 266 degrees intake, 274 degrees exhaust
Duration at .050: 216 degrees intake/224 degrees exhaust
Valve Lift (with 1.6 rocker): .545 inches intake/.555 inches exhaust
Lobe Separation: 112 degrees
Powerband: 1,600-5,600 rpm
If you look at just advertised duration, the Comp grind looks less aggressive than the Ford Racing cam. But when you check duration at .050, both cams are virtually the same. This is an example of why duration at .050 is a much better comparison method.
Where our cams diverge is in lift and lobe separation. The Comp Xtreme Energy grind offers far more lift and a relatively wide 112 degree lobe separation, so it makes good power across the rpm band. The extra lift and duration on the exhaust side helps improve the small block Ford’s poor exhaust breathing. Comp recommends the cam for cars with 3.27-3.73 gears, Mass Air systems, and mild modifications like a larger throttle body, headers, and free-flowing exhaust. Either a five-speed or an AOD automatic with a mild stall converter would work with this cam.
The Ford Racing X303 has slightly lower lift figures, but is ground with a narrower 110 degree lobe separation. That makes the cam more biased toward high rpm power production. In fact, peak horsepower rpm comes at a rather lofty 6,500 rpm, almost 1,000 rpm higher than the Xtreme Energy cam. Ford Racing says the X303 should be used with a five-speed manual transmission.
We hope this little primer gave you the knowledge you need to choose the right cam for your street ride. If you want to get a PhD in camshaft-ology, companies likeCrane, Comp Cams,  Iskenderian , and Lunati have loads of information on their websites to help you become Dr. Bumpstick. Happy cam shopping!
