ringing after changing speakers
netwarrior36
Posted: 05/25/13 12:53 PM
Changed dash speakers in 91 j body first one went fine then hooked up the second one and now something under my dash is ringing and the only way can't get it to stop is unhooked battery. I unhooked the battery before putting them in one at a time.
"If it breaks it was good, and if it doesn't break it's bad."
1978 Chevrolet Nova two-door hatchback
Posted: 05/25/13 01:33 PM
Did you pinch a wire between the new speaker and its mounting surface like the metal frame of the dash?
netwarrior36
Posted: 05/25/13 01:45 PM
No I just connected the existing two wires
netwarrior36
Posted: 05/25/13 04:15 PM
I guess it was solved, I unhooked my battery for a while went back out and the problem was gone. Hooked up the wires backwards.
Posted: 05/26/13 08:15 AM
Hooked what wires backwards? Speaker wires or battery cables?
limocraze
Posted: 06/20/13 11:03 AM
Same problem here, do you know any device to make it easier.. Like, 2-in-1 converter which includes Battery Charger and Mobile Keeper at the same time.
http://www.sslimousine.com
