gen v bbc 454
rmascetti69
Posted: 08/26/13 06:01 PM
I have a mercury marine gen v 454 . bare block. im looking to get about 550 -600 hp out of it. the guy I got it from said one cylinder needs sleeved. is it worth rebuilding this motor or getting something different. dont know much about gen v motors. any an all advice is welcome
Posted: 08/26/13 08:03 PM
STOP.... before you do ANYTHING... MEASURE THE MAIN bores...
many marine 454 engines were built using OVERSIZED main bearing shells..
what.. yep... mains... +.010 and then what ever under size for the crank..
these oversized main bearings are almost impossible to find.. king bearing made them.. but there are NO more from them... will they make more???
anyplace that's likely to have them is the GM marine parts division..
please also before anything else..   have the block cleaned and magnafluxed..
you probably already know all this.. but i thought i would add this in..
well maybe they are not that hard to find..
http://titanengines.com/chevrolet-marine-454-7-4-ohv-v8-bearing-set-main-for-with-0-010-oversized-flange.html
but then i wonder.. is this a oversized bearing set with an extra thick thrust flange.. or oversized bearing shells for the marine engines that were line bored .010" oversize..
this might help.. seems there are blocks that are also bored +.020 oversize on the main bores...
http://www.competitionproducts.com/Chev-BB-Rod-Main-Bearing-Kits/products/1406/
rmascetti69
Posted: 08/27/13 06:15 AM
yes def gonna.have block.cleaned n checked for cracks n stuff. but will measure the main boars. but say it is over sized is it worth building to get 600 hp out of it
rmascetti69
Posted: 08/28/13 05:52 AM
thanks for the links helped out
Posted: 08/28/13 07:00 AM
Why fool with a block that is questionable like that. I would not advise it and look for something that is in better condition.
