what chevy 350 performance cam??????
joseluis84
Posted: 03/24/13 05:13 PM
hello tthis car is 4 daily dravin and use and i whant 2 know how much horse power 2  expect ?? .... some  knows   what  would be   good  cam .......
my engine is  chevy  350  .
bore 40. over   kb forged piston 11.01         automatic transmision 350
ported head 74cc                                shift kit,racing clucht
valve 2.02 int     1.60 ex                     converte 2,700
100.lbs 3 spring whit retainers
edelbrok performen rpm intake
holley 670 streat avenger
this is a proyect  i haven put togeter all the  engine  yet.  am lookin  4  a good cam an roller    what  number  or  wich one ???
Posted: 03/24/13 06:41 PM
joseluis84 welcome to CHP.
Here are the 2 cams of choice. They are Comp Cams Hydraulic Roller retrofit cam kit. When you order any new cam make sure you get the get the Matched Valve Springs  for the cam. If you order the Cam Kits they should have all the parts you'll need. Just 3 Questions
1.What Rear gear ratio are you running?
2.How tall are your rear tires?
3.Car your using?
My first Cam Choice
Comp Cam Extreme Enery Cam. P/N 12-422-8  Grind #XR270HR
Good to use with a stock torque convertor and exhuast. Aftermarket intake manifold, and 3:70-4:10 Rear Gears
1600-5400RPM   .218/.224 Dur. @.050  .495/.502 Max Lift
110* Lobe Seperation 106* Intake Center/Line
With the parts you have and NO MORE then a 10:1 compression for pump gas. You Can probably make 350 Horse Power.
Posted: 03/24/13 06:50 PM
2nd Choice for a Cam
Comp Cam Extreme Energy Retrofit kit.
Cam P/N 12-423-8  Grind #XR276HR
This is a performance Cam. Has a Nice performance Choppy Idle, and requires at least a 2,000 Plus RPM Stall Convertor. Aftermarket intake, headers, and Gear 3:70 to 4:10
Cam Specs. 1900-5600 RPM .224/.230 Dur. @.050  .502/510 Max Lift with Modified Heads
110* Lobe Seperation 106* Center/Line
If you make all the changes and modify your heads, maybe 375 Horse Power.
JoseLuis make sure you order the Extreme Energy Retrofit Cam Kit.
joseluis84
Posted: 03/24/13 07:18 PM
this  engine  will go  in  mazda  pick-up b2000   1985  am usin  the orijinal rear  end  i  think  is near  482
joseluis84
Posted: 03/24/13 07:22 PM
the  engine  head  are alredy  hi modified  the machin shop  made  evrithing big  valve  big port, angel job .. what alse  could i do  whit the head?    and i got  2,700 RPM Stall Convertor
Posted: 03/24/13 07:35 PM
your rear gear raito is insane with the truck you describe.Unless you live One eigth of a mile at a time. it really won't be any fun after a short time.
joseluis84
Posted: 03/24/13 07:45 PM
could i  use  higer cam?  something like this
Basic Operating RPM Range: 2,500-6,500
Intake Duration at 050 inch Lift: 238 Exh 238 Duration at 050 inch Lift: 238 int./238 exh  Valve Lift with Factory Rocker Arm Ratio: 0.525 int./0.525 exh
Posted: 03/24/13 08:52 PM
The heads you have, are they modified facotry heads? They sound like machined 882s or something similar....74cc chamber w/machining for bigger valves...just trying to figure out what he's got.
The last suggestion in place will give you
enough wheelies to drive you nuts.
Good luck anyway...Skyeking
joseluis84
Posted: 03/25/13 04:29 AM
the head  are modified factory head .......   whit == racing  spring,retainer,lockpin 4 the roller, racing valve 2.02 /1.60 ,intake and ex are ported the machin shop they  made  evrithing they could  do
joseluis84
Posted: 03/25/13 04:37 AM
am  seeking  400hp  don't  know  what more changes  i  could make .....         forgot 2 mencion  i got   msd 6al  and  msd blaster coil
Posted: 03/25/13 04:38 AM
Heay Guys
Is this a pulling truck by chance?
The 4:82 Rear Gear is OKAY if you have a 33" Tall Tire...
But as the Skylark said thats a lot of Rear Gear.
They The Mazda P/U were geared very low because they had a 5 speed transmission, and a very tall tire....
and they were a truck!
On the Cylinder Heads, just make sure you have the Clearances between the Valve Spring Retainer and the top of the Valve stem (Guide)...
Joseluis84
What is your main purpose (Use for your truck).
The Cam choices I posted for you are for the head you posted.They are the biggest for what you Posted.
Your heads: THE INTAKE SIDE: Gasket match and go 1" into the throat of the Intake Port of the Cylinder Head, smooth any area that may have excessive casting flash and then do the same to the  Intake Manifold. Then Bowl clean up and port to the Edge just under the the Intake Valve. "Some FYI" don't over do smoothing the intake side. Use the tootsie rolls to claen the intake port.
The Exhaust Side. Gasket Match to your Header size only. NO BIGGER.
Clean the Bowl area Under the Exhaust Valve. Smooth any casting with tootsie rolls.
Jegs or Summit Sell porting and Polishing kits. I don't suggest doing this unless you have experience with Porting Cylinder Heads.... Grin  Cool
Posted: 03/25/13 05:08 AM
joseluis84
WHAT IS THE GOAL FOR YOU AND YOUR MAZDA TRUCK? We need to know this or we can't steer you in the right direction.
What is your BUDGET? Remembering that Horse Power cost money. It did in my day and it does today. Today you can make a phone call, and have your parts tomorrow...Not in my day...lol...
A:We need to know this as your wanting to make some Horse Power, will be limited to that. To much HP for the street and you will be miserable with your Mazda.
B:If its a full time Drag Race Truck we need to know that
C: if its part/time street/strip we need to know that! How much street? How much strip?
D:If it's a Pulling Truck we need to know that
If you don't give us the input we need we can't help you. You came to the right Forum if you want to go fast,BUT help us to help you
MSD ignition is a good start. But what type of Distributor do you have?
Now if you read what I posted about your Horse Power Numbers. I said somewhere in the 350 to 375 Horse Power depending on your Cam. You can find some horse power in your tune up.
Your Mazda Truck is a light weight. 350 HP will get that moving rather quickly.
If you want another 40 Horse Power? Put the Gen 1 cylinder heads in the corner for another project. Then purchase a set of aftermarket cylinder heads. Okay.
With that said here is whatelse can be done.
This is for an example only"
1:Aftermarket cylinder heads then you can go to the following!
2:Bigger Camshaft
3:Bigger carburetor (Maybe a 750 double Pumper)?
4:Rear Gear is Okay
5:May need to redo your trans or risk blowing it up
6:More stall speed for your convertor
7:The list will get bigger as your expectations get bigger, and your Budget will dwindle...
joseluis84
Posted: 03/25/13 01:05 PM
this  truck is  4 daly drivin  but not long distance , and i  want 2  use this  truck at  night  4  racing   1/4mile aporx.
this is not a  work truck  or this truck will never pull nothing  ...
1-  the rear gear  am planin on changin  it and get  4.10  but i  want 2  finish the engine  first...
2-the  transmision is ok  i know  it  will  hold  beacuse the car   it came  from  had  572hp at the wheel
3-budget 1,300 left  alredy spend 2,400
