Posted: 07/15/13 06:50 PM
I am going to check the piston to valve clearance on my Dart SHP 400 and from all the literature I have read the clearances need to be .08 intake and .10 for exhaust. Does anybody care to give me a yes or no on those values? I have read so many different articles and books, from what I have read it ranges from .055 - .08 on intake, .075 - .10 on exhaust. Are these safe ranges?
Posted: 07/15/13 07:35 PM
I always tried to get at least .05 on the intake side as the intake does not expand as much as the exhaust. On the exhaust I would go with about twice as much. There is no harm in going with more clearance, just don't go a lot less. I have read where some builders go as close to .01 to .015 on the intake side. Now if you have aluminum rods I would triple those numbers.
Posted: 07/15/13 07:41 PM
No, the rods are forged steel rods!
Posted: 07/16/13 08:35 AM
Minimum piston to valve clearance is .080” on the intake and .100” on the exhaust valves. If aluminum connecting rods are being used, add a minimum of .030” to these suggested clearance figures. Aluminum rods will stretch and expand more than steel rods.
Note: Be sure to check piston to valve clearance after the cam has been degreed. The positioning of the cam in the engine will greatly affect the piston to valve clearance.
Posted: 07/16/13 04:45 PM
Hi Poncho Man, Long time no see. All the best to you and the gang And RustyNutts. Are you busy turning over a rare Dollar??.. See you when the Mud dries Pal...MeinOz..
Posted: 07/16/13 05:27 PM
Yes the cam has already degreed and rephased! The cam specs are 525 lift(modified to 563 with 1.6 rockers), 224 dur @ 050, LSA is 110, intake center is 106, intake closing angle is 66 but will be retarded 4 degs. The degreeing process found that the duration is 1 degree short @ 223 degrees both valves, Lift is exact on intake and .001 short on exhaust and the intake closing is 65, so retarded 4 degs it will be 69.
