hp estimates on 454?
dakotar95
Posted: 05/06/13 09:07 AM
Hi guys im new here and was wondering what your opinion was on the power my 454 will produce after the build. I am just curious, thanks
stock 454 out of 78 truck
stock dished pistons i think 8:1 comp.? (hp gain with domed pistons? maybe 10:1?)
performer rpm cam: 240 int./246 exh,  LSA 112*
performer rpm intake
750 cfm qjet
hooker super comp headers
large oval port 781 heads  (hp with stock heads? hp gain with bigger valves?)
im just a 17 year old hoping to be a gear head lol this would all be going in my 72 chevelle 4 speed
thanks guys
Posted: 05/06/13 12:31 PM
Maybe 400hp in that configuration.
IMO that cam isn't the best option for your heads and compression ratio.
Don't get hung up on hp numbers, they're not what moves the car. Without changing anything else, the Performer cam will make your combination more entertaining.
Posted: 05/06/13 01:09 PM
I agree with Joe about 400 should be close.
That BB with better heads, a roller cam and rocker setup, good single plane intake and a dominator carb and higher compression, could get you close to 600hp. It is wise to start small and get used to a milder combo before you step up. Performance is like a drug the more power you get the more you want. I stopped when I could no longer put all I could make to the ground even with 17" wide slicks.
dakotar95
Posted: 05/06/13 10:44 PM
would this cam be better matched? if it is, how would it perform compared to my performer rpm?
Posted: 05/06/13 11:44 PM
 I would opt for about 7* or 8* less on the inlet @ 50/1000".
 Keeping the torque for rice burning adventures.
 Good luck with a great motor....Skyeking..
Posted: 05/07/13 04:42 AM
Did you have another cam in question or are you asking about the Performer v Performer RPM?
dakotar95
Posted: 05/07/13 07:40 AM
Sorry i had a link but it wouldn't let me post it last night. It was a lunati voodoo cam i believe. Around 227 int. 233 exh. ? And 110 lsa. Ill try and post the link later today
dakotar95
Posted: 05/07/13 08:27 AM
Lunati 10110703 - Lunati Voodoo Camshafts
I was correct: 227 int. 233 exh. 110 lsa
Wat do you guys think?
p2-72chevelle383
Posted: 05/07/13 12:46 PM
That cam would help a little by bleeding off less compeession. But with 8to 1 cr your cam and power choices aee limited.
p2-72chevelle383
Posted: 05/07/13 12:52 PM
With the engine combination listed above, you need a lower duration camshaft to optimize the package. If you are willing to raise the compression ratio to 9:1 or 9.5:1, then you can expect perfomance from the Lunati cam you've chosen. If you are going to build a motor with 8:1 compression ratio, you have to cam the engine accordingly.
p2-72chevelle383
Posted: 05/07/13 03:01 PM
+1 however with 8 to 1 that's maybe an rv cam at best. Anymore duration will be a turd on the low end
p2-72chevelle383
dakotar95
Posted: 05/07/13 09:59 PM
ok how about this, what if i achieve 10:1 cr with new pistons. What does that change power wise and matching the parts with each other? would the rpm cam be better suited then?
really sorry for all the questions guys, im just a kid trying to learn. Thanks for the knowledge, i appreciate it.
Posted: 05/07/13 10:19 PM
with 10/1 pistons and the limited heads the 230* cam
would be as high as I would go personally. Skyeking...
dakotar95
Posted: 05/07/13 10:32 PM
limited heads? ive read everywhere that the 781 heads are the best flowing production heads out there along with 049's. what am i missing?
Posted: 05/08/13 04:44 AM
If you are satisfied with production performance production parts are fine, but if you are looking for more performance than what the factory made you need to upgrade your parts selection.
You can use the rpm cam if you want but I can tell you from experience that Edelbrock's RPM cams leave some to be desired. Don't believe everything you see in the manufacturer's catalog/website.
