moser rearend
gk348409
Posted: 05/04/13 06:15 PM
just installed a moser 9" in a 60 biscayne. pmt 4 bar.driver side wheel is 1 1/2" from were it should be. .right wheel is in stock position..any ideas??? the driver side is inboard further than it sould be..moser says it is jig welded o.e.m. if the rearend is pulled to the driver side. the driveshaft will rub the driveshaft tunnel. it's got me layin' awake at nite....sujestions welcome!!!!
Posted: 05/05/13 04:22 AM
if the car is lifted or lowered, it can do that when useing a panhard or track bar type set-up.
  something doesnt sound right with the driveshaft rubbing.
gk348409
Posted: 05/05/13 08:40 AM
redneckjoe,thanks for reponse...not for sure if driveshaft will rub,have'nt tryed to adjust panhard bar yet..it looks like it might...car height has not been changed..remember the driveshaft goes though the frame. going to loosen all suspenion bolts and see if panhard will pull it over some.can't see it bring'in it over 1 1/2".go'in to try it tomarrow...thanks again,G.K.
Posted: 05/05/13 12:39 PM
your welcome.   maybe youll only have to move it 3/4 of an inch to get it centered up?    is your moser narrower then what came out of there?
Posted: 05/05/13 03:54 PM
Something sure sounds strange there.
I would compare the suspension mounts from the original rear to the Moser and see if they match up. If I remember correctly the 60 Chevy uses coil springs with a link type setup. As Joe said the panhard bar is what locates the rear with that setup.
Some of my race cars had that setup and if I raised or lowered the rear with the adjustable springs the rear would change position.
gk348409
Posted: 05/06/13 08:37 AM
yes,measured the mounts.may crawl under it today and recheck again.it's got me scatch'in my head!!! thanks again guys...G.K.
Posted: 05/06/13 01:12 PM
How about a bent frame..
If this was an older drag car that is a possibility.
I have seen some frames without roll cages get twisted up and unibody cars that twisted the whole body.
Posted: 05/07/13 12:16 PM
I agree with Dave632. I would take it to a good frame shop and have the chassis checked. I've used Moser rear-end parts in the past years and they are a quality compamy. Hope you find it.
Posted: 05/08/13 04:02 PM
Hi People..Z/g kin Oz...
