1986 Camaro gas tank
bjmckay
Posted: 04/16/13 02:39 PM
I am trying to get tank out of 86 Z28,is there anyway to get it out without cutting the exhaust pipe at rear?
Posted: 04/16/13 05:07 PM
if its stock exhaust,...jack the car up and support it by the subframe.   take off the rear tires.    put a jack under the rear.   unbolt the shocks at the rearend.   lower the rear.   watch your brake lines & coil springs.  the springs will fall out.   unbolt the exhaust at the catalytic converter, and the 2 hangers in the back.   should slide right out.
bjmckay
Posted: 04/17/13 01:20 AM
exhaust welded in at converter by previous owner.
Posted: 04/17/13 04:40 AM
If you make straight, clean cuts, an exhaust coupler pipe could be used to reconnect the exhaust.
just a thought
