chevy 305 head 350 swap help? stupid?
chrishd2008
Posted: 01/31/13 10:12 PM
I have a 85 camaro with a 305tpi I built a 350 bored 30 over with flat top pistons each piston has 4 valve reliefs  I believe they are silvolite? I took the 305 tpi heads and put them on the 350  and the cam is stock also, so do I have 58 cc heads? and if so what would be my compression ratio now? im getting a chip burned and the guy needs to know this before he burns and can any one give me some tips on this? im just looking for a fast sunday driver
Posted: 01/31/13 11:27 PM
You'll have to post the casting numbers before anybody can say for sure what heads you have.
http://www.kb-silvolite.com/calc.php?action=comp
This link is to a CR calculator. Notice that several measurements are needed to acurately calculate CR.
busterrm2013
Posted: 07/09/13 11:42 PM
CR is going to be between 10.45 and 10.70 if your quench is .042
busterrm2013
Posted: 07/10/13 05:51 PM
If I remember right most of the guys think the 305 head is good for a door stopper. I have never used one for any purpose so check with the guys who know about that head.
Posted: 07/11/13 04:34 PM
If the heads have 1.84" inlets then have the throats
behind the valve seats ported on the exhaust valves as
a priority
If not then look elsewhere for value.  Good luck.
