Question about 1986 chevy c10
Gripy
Posted: 03/29/13 01:35 PM
Can I use a 1976 chevy c10 core support on a 1986 chevy c10?
Posted: 03/29/13 02:22 PM
73 thru 87 full size chevy and gmc 1/2, 3/4 and one ton front sheet metal can be swapped if you use all of the sheet metal...
will the 86 core support fit under the 76 sheet metal.. probably not...  as there is a height difference...
at some point in the 80s.. gm took some of the nose height out of the front end.. i don't know what year that happened..
Getbigpage?Pageid=36318
Getbigpage?Pageid=36307
Posted: 03/29/13 02:25 PM
probably the last year might be an 80...
Getbigpage?Pageid=58228
i have not delved into exact part numbers as things change from year to year
Posted: 03/29/13 02:36 PM
Getbigpage?Pageid=55214
Gripy
Posted: 03/29/13 04:53 PM
Can I bolt the 1976 c10 core support to the 1986 c10 and with all the other 1976 metal, will it fit together properly?
