holley 80457 to gm 346250 intake
wetinnw
Posted: 03/25/13 12:44 PM
vacum for break booster
Posted: 03/25/13 01:25 PM
Do you have a question to ask or a statement to make?
Posted: 03/25/13 02:59 PM
Most Holley carbs are taped for a fitting in the back side of the carb. There maybe a brass plug in the rear of the carb. You will have to look for it. (Under the rear float bowl)... I can't do that.
If it's not there. Then sometime the Factory intake has a taped fitting in the intake that will require a 90* elbow fitting. For the vacuum source to the power brake booster...The same goes for the intake. If it's a very early Factory Intake you may not have a vacuum source in it. Back in the day Hi Po engines didn't have power brakes...(Do to Lack of a good vacuum). The cam was usually too big.
If there isn't a fitting in either. Then you can look for a 1" spacer plate that has a port built into it, so you can run a vacuum source to the Power Booster...
Or get creative and drill and tap a vacuum source in the intake manifold, for the power brake booster..
You need engine vacuum for the power booster to operate properly...
wetinnw
Posted: 03/25/13 07:55 PM
thank you for the imfo . i used the threaded vac line behind the carb ...   havent fired it yet.maybe later
