Item Posts
Sort Order
Posted: 02/05/13 05:27 PM
shafiroff unveiled their new all aluminum 509 w motor.anybody got a price/horsepower/torque etc.
Posted: 02/05/13 07:20 PM
found it. the new for 2013 all aluminum 509 motor packs just north of 600 ponies and about the same ft/lbs all for the low price of 21,500.00 (ouch!!)
Posted: 02/05/13 09:54 PM
This is the thread we should direct all the budget 500hp 305 questions to.
Cool motor though.
Posted: 02/06/13 05:09 AM
68scott385: This is the thread we should direct all the budget 500hp 305 questions to.
Cool motor though.
+1 Here is the link to Shafiroff Racing
http://www.ultrastreet.net/engines.php
Posted: 02/17/13 08:17 PM
Great link, serious motors! All u need to do now is change "the judge" to maybe "yenko" or "lingenfelter"......hahaha!
Posted: 02/17/13 10:43 PM
Very funny.,. peculiar funny. Welcome to the forum.
Posted: 02/18/13 06:26 AM
And Don't Forget Lamar Waldon In Atlanta He Has Some Down right Sick W motor Parts
http://lamarwaldenautomotive.com/
Posted: 02/18/13 09:21 AM
Introductory Sale Price $21,500.00 Includes Carbs & Ignition
You've Been Dreaming About It. You've Waited For It. Now It's Finally Here! This Is Probably The Coolest Engine We've Built In The Last 10 Years And Is Guaranteed To Put More Smiles Per Mile And Generate More "Oohs & Aahs" Than Anything Else On The Planet!
If You're A 409 Buff ... This Bud's For You!
Horsepower Torque Bore & Stroke Compression Ratio Fuel Requirement 565 @ 5600 RPM 615 @ 4200 RPM 4.370 x 4.250 10.25 to 1 91 Octane
World/BMP 409 Aluminum Block w/Steel Billet Caps Eagle 4340 4.250" Stroke Steel Crank Eagle 4340 6.385" H-Beam Steel Rods Clevite 77 "H" Series Main & Rod Bearings Custom 10.25-1 Aluminum Pistons w/Coated Skirts Total Seal Plasma Moly Ring Set Comp Custom Hydraulic Roller Cam Street Performance Retro Fit Hydraulic Roller Lifters Cloyes Billet True Roller Timing Set w/Torrington Bearing Edelbrock 409 Aluminum Heads w/SSRE Port Modifications Custom Stainless Steel 2.250/1.750 Valves Comp Cams 1.530" Roller Springs w/Steel Retainers ARP Custom Aluminum Block Design Head Stud Kit Comp Cams 1.7 Ultra Pro Magnum Roller Rockers Chromemoly (1) Piece .080" Wall 3/8" OD Pushrods Cometic MLS (Multi Layer Steel) Head Gaskets Edelbrock RPM Dual Quad Large Port Intake SSRE/Moroso Custom Stroker Oil Pan w/Windage Tray Moroso Race Prepped Oil Pump w/Tig Welded HD Pickup Polished Aluminum Front Cover w/Billet Timing Pointer Hi-Performance Degreed Harmonic Balancer Custom Cast Aluminum Valve Covers w/Polished Fins & Logo New Shafiroff Racing Engraved & Painted 509 Logo Edelbrock Vintage Finish 600 CFM Dual Carbs w/SSRE Mods Edelbrock Progressive Throttle Linkage MSD Ready To Run Billet Distributor w/Custom Machining Moroso Custom Wires w/Looms Complete Assembly Internally Balanced Individually Dyno Tested & Tuned Actual Dyno Sheet Provided
Hot Hydraulic Roller Add $2500.00 For Those That Want Even More Power Than "The Classic" The HHR Is For You! We Use Special "Proprietary Grinds" On Our Custom Hot Hydraulic Roller "Round Lobe" Billet Cam Along With "Ultra Hi-Rev" Pro Series Hydraulic Roller Lifters And Custom 10.75-1 CR Pistons. This Version Also Comes Standard with Fully CNC Ported Heads And Premium Alloy Valve Springs To Maintain Race Engine Performance With Hydraulic Roller Convenience.
Edelbrock 409 Heads w/SSRE Fully CNC Proprietary Porting Comp Custom "Round Lobe" Billet Hydraulic Roller Cam Special 7/4 Swapped Firing Order High Rev Pro Series Hydraulic Roller Lifters Isky "Enduro Design" Premium Valve Spring Package Custom Manley 10° Steel Retainers and Locks Edelbrock 409 Large Port Intake w/SSRE Port Matching Custom 10.75 - 1 CR Pistons Horsepower Torque Compression Ratio Fuel Requirement 615 @ 5800 RPM 638 @ 4500 RPM 10.75 to 1 93 Octane
Posted: 02/18/13 09:48 AM
that's a bad a-- motor but, I wonder how many they will sell at that price. when you can get a pretty cool motor for a fraction of that cost!
Posted: 02/18/13 03:53 PM
When I was running the Pro Mod shafiroff had a bad reputation among the racers. He was reputed to take money and not deliver among other problems. I never had any experience with him.
Posted: 02/18/13 04:51 PM
It's A W-Motor, It's All You Could Want. If your Like Me and Stuck In the 60's. PS that Bore and Stroke is More like 425ci isn't it. But who's Countin' This kind of engine is a life Style More than Any other Chevy Motor. doesn't have "the Leigon Of Followers" the Small and Big Block Has, But the Faithful Stand Ready.
Posted: 02/18/13 06:22 PM
509 is what they are claiming
Posted: 02/18/13 06:28 PM
4.37 x 4.37 x 4.25 x .7854 x 8 = 509.9559788, if you want accuracy
Posted: 02/22/13 02:40 AM
That motor is pure EVIL....But Nice!!!!!!!!!!!!!!!!!!
