Key lock removal - 76 Camaro
bigdee2
Posted: 10/21/12 10:35 AM
I've pulled the steering wheel, hug, turn signal and hazard levers/knobs and the turn signal aparatus with the 3 screws.
I just can't get the key cylinder out. Is the tab to depress with a small scew driver basically the end of the rod that runs down the steering column under the dash and hooks into the ignition switch interrupter? I've even tried an ice pick in the hole where the screw goes to mount the turn signal lever.
I have to be doing something wrong! Please help!! Derek
It does have tilt steering. Basically, you can start the car, but the key stays in the "Run" "Accessories On" position. And the chrome/silver outer piece around the key cylinder can just turn 360 degrees and keep going.
Posted: 10/21/12 12:15 PM
17 1
